I'm here. I'm running irVision on an R30ib+ running V9.3. And I had this irVision task working yesterday, on this same target. The only thing I've changed since then is opening up the Scale tolerance on the GPM tool.
The thing that has me confused is that the GPM is succeeding, but the GET_OFFSET command in my TP program is jumping to the "failed" LBL. By the manual, this should only happen if the find fails, or if the limit check is exceeded, and I don't have a limit check set up.
In fact, my VR in the robot is getting the same values I see in the irVision page. So, I'm a bit stumped as to why my GET_OFFSET is failing.
