coordinate upgrade syntax
  • iavi
  • July 28, 2023 at 2:32 PM
  • iavi
    5
    I should take the actual coordinate of a certain number of points (i.e. XP1.E1, XP2.E1, ...) from dat file and sum to it a value maybe inside a FOR loop before performing SLIN.
    Something like
    XP1.E1_new = XP1.E1_old + i*360
    XP2.E1_new = XP2.E1_old + i*360
    Which is the correct syntax?
    Many thanks in advance!
  • massula July 28, 2023 at 2:55 PM
    Approved the thread.
    SkyeFire
    1,051
    9,423
    • July 28, 2023 at 3:12 PM
    XP1.E1 = XP1.E1 + 360
    However, this will permanently overwrite the value in the .DAT file. So be aware.
  • Florida
    103
    • July 28, 2023 at 3:23 PM
    Quote from iavi
    Something like
    assuming XP1.E1_old is the original retained value, it would be like
    XP1.E1 = XP1.E1_old + ( i * 360.0)
    Calculation need to be done inside the local src file, before you have the motion to P1.
    Unless you work with Global positions and variables.
  • iavi
    5
    • July 28, 2023 at 3:31 PM
    Quote from Florida
    ok, as far as I understood before the calculation
    XP1.E1 = XP1_E1_old + ( i * 360.0)
    I have to initialize the variable XP1_E1_old = XP1.E1
    Something like that?
    XP1_E1_old = XP1.E1
  • Florida
    103
    • July 28, 2023 at 3:40 PM
    if you overwrite XP1_E1_old with the last position of the calculated E1, your point will deviate a lot.
    Always keep a Start value that never changes and do your calculation.
    I don't know your application, so is it a linear slide, and endless running external axis or a spindle kind of thing? It is like Google maps, to calculate the direction to a target you need to know the origin, your start-point
  • KRL Variables
