Hi all,
I am in the process of setting up a Kuka KR210 at my business. I got everything up and running yesterday ... almost ... except the CPU, which apparently has a bad power supply. A New one is on order.
My main question involves a few things I need to do right after startup. I know how to use the mastering tool, so I'm good with that. Firstly, I am going to want to set up parameters for Axis 1. My robot is installed in a place where if it rotates all the way around it will probably take out the wall behind it. How do I set stops so that the robot will only swivel to a certain point? I can't figure out how to word an internet search for this answer ... so here I am.
The new power supply should arrive Monday, so after that is fixed I'd like to get this nagging question solved.
