record user frame updates
  • deltaplex15
  • July 18, 2023 at 2:00 PM
  • deltaplex15
    22
    Hey everybody
    I am trying to figure out if there is any way I can record or log any time a user frame has been updated or a PR has been updated. Even if it just loads a count into a register (I would prefer a date and time of the update but I'm not even sure if this is possible lol).
  • hoitzing
    24
    128
    • July 18, 2023 at 3:36 PM
    You would have to continuously monitor the user frame of interest, and compare the XYZWPR values to a previous version that you stored. Backgound logic sounds perfect for this, except you can't use Position Registers in BG Logic. To avoid PR's I would say get the values directly from the system variable ($MNUFRAME[1,*]) but I don't know of a way to get individual XYZWPR values directly into a register in TP. The system variable returns a position and, again, PR's are benched.
    This would leave multitasking as the only option left I can think of, in which what you're trying to achieve is very easy to do in either TP or Karel, using the method I described above.
    For your info, should you choose to use the multitasking option with Karel, it is possible to get the system's timestamp at the time a change is detected. It's probably pretty doable via TP too if there's some system variable with the timestamp you can access (which I'm pretty sure there should be).
