Turn Off the robot
  • MR21
  • July 17, 2023 at 6:33 PM
  • MR21
    24
    Hi, I'm new with Fanuc.
    I would like to turn the servo off when the robot is in home position.
    How can I do?
  • Doctor_C
    33
    198
    • July 17, 2023 at 9:17 PM
    It will automatically after 20 seconds.
    Robot Brakes
    $Param_Group.$SV_OFF_ALL If True, automatic servo on/off will be applied to all axis
    If False, automatic will be applied to individual axis in $sv_off_enb (set to false for bad motor brake)
    $SV_OFF_ENB Controls whether or not each servo uses a timed servo shutdown, used with $sv_off_timer to shutoff servos (set each axis to false for bad motor brake)
    $SV_OFF_TIME Defines the time interval, in milliseconds, after which the servo motors are shut down.
  • MR21
    24
    • July 18, 2023 at 9:48 AM
    Quote from Doctor_C
    Robot Brakes
    Thanks! So if the robot has not moved for the time set in $SV_OFF_TIME, servo motors are shut down wherever is the robot?
  • TitusLepic
    113
    7
    442
    • July 18, 2023 at 5:19 PM
    Quote from MR21
    Yes
  • MR21
    24
    • July 18, 2023 at 5:23 PM
    Quote from TitusLepic
    Yes
    Can't I do this only for my home position?
  • saberdud
    46
    • July 18, 2023 at 5:30 PM
    You might be able to adjust that parameter from the BG logic based on the IO you have configured in that reference position, then change it back as soon as the robot moves out of that position.
  • MR21
    24
    • July 18, 2023 at 5:51 PM
    Quote from saberdud
    Thanks! Which instruction should I use to adjust the parameter?
  • saberdud
    46
    • July 18, 2023 at 7:27 PM
    Quote from MR21
    I'd try to set it equal to a number of second just in an equals line, if that doesn't work, see if the parameter is able to be changed in a program. Sadly, if it's not, then this approach falls flat and you'll need to find another approach.
Similar Threads
  • Should $MOVE_ENABLE be assigned to an input other than $IN[1025]?
    • robotninja
    • February 9, 2023 at 9:57 PM
    • KUKA Robot Forum
  • Interrupt Example
    • SkyeFire
    • March 18, 2021 at 8:25 PM
    • Manuals, Software and Tools for KUKA Robots
  • Turning UI with flag
    • Alicia Agane
    • April 27, 2023 at 1:34 PM
    • Fanuc Robot Forum
  • Beginner needing some guidance on program changes please
    • Sw0028
    • July 11, 2022 at 10:25 AM
    • Fanuc Robot Forum
  • Pausing Program in Auto Mode
    • Searchligt_1
    • June 9, 2022 at 8:14 PM
    • Fanuc Robot Forum
  • Errors when opened in the morning
    • eeleker
    • January 11, 2022 at 7:43 AM
    • KUKA Robot Forum
  • Code for Robot losing track of its position. Can anyone spot areas I need to address to figure out why?
    • cat91345
    • December 7, 2021 at 1:17 PM
    • Yaskawa Motoman Robot Forum
  • Servo tracking error axis L and B
    • cat91345
    • December 2, 2021 at 9:13 PM
  • Measurment of tool with interrupt when the toolsetter/button is clicked and then unclicked
    • martenH
    • November 30, 2021 at 4:02 PM
    • KUKA Robot Forum
  • Mitshubishi RV-2AJ
    • Project5
    • March 10, 2015 at 10:00 AM
    • Mitsubishi Robot Forum
