Offset a target point
  • GoodFellas41
  • July 3, 2023 at 11:46 AM
  • GoodFellas41
    23
    Hi guys,
    I'm working with KRC5 Controller and KR16 R1610-2 robot.
    I have 48 pick points. (12x4)
    There is offset on only 2 axis(X and Y)
    There is 300mm between each workpieces on X axis and 40mm in Y axis
    I dont want to record all these points separately.
    I would like to offset my targets points but I don't know how to give the offset.
    How can I set offset and what do I need to be careful about?
    Thank you
  • kwakisaki July 3, 2023 at 11:47 AM
    Approved the thread.
  • Fubini
    270
    1,866
    • July 3, 2023 at 12:09 PM
    Read about the geometric operator ":". This has been discussed many times in the past and can be found multiple times in the forum.
    Basically
    XP:shift ; shift in tool
    shift:XP ; shift in base
    Fubini
  • Mentat
    61
    5
    243
    • July 3, 2023 at 12:35 PM
    If you are new and/or in a hurry reading about bases might be quicker/easier.
    Do keep in mind offsets with geometric operator will not stop advance run pointer, while changing $base - will.
    SkyeFire
    1,038
    9,371
    • July 3, 2023 at 4:06 PM
    This might be helpful. The GridFunctions module performs Base adjustments based on X, Y, and Z counters (using the Geometric Operator), and the GridExample program is a program that uses the GridFunctions module.
    ...hm. Looking at it again, I can see I need to update the example program. I wrote it for someone who needed a unique Rz rotation for the first row, so two different pick positions were taught. Still, this should demonstrate the basic operation well enough.
    Files
    GridFunctions.zip 7.15 kB – 23 Downloads
Similar Threads
  • Incorrect motion when changing bases
    • theemrroboto
    • April 27, 2023 at 12:29 AM
    • KUKA Robot Forum
  • Z axis offset movement
    • automan
    • January 21, 2023 at 3:27 PM
    • KUKA Robot Forum
  • how to Write a code in rapid to account for Rotation?
    • Scoutpwner
    • October 27, 2022 at 2:54 PM
    • ABB Robot Forum
  • RobotStudio Simulation: Fixed Tool
    • SkyeFire
    • September 12, 2022 at 5:42 PM
    • ABB Robot Forum
  • Programme simplifying help.
    • Roboflop28
    • August 5, 2022 at 9:31 AM
    • Kawasaki Robot Forum
  • Epson RC70 - J6Flag issue
    • DmcA
    • May 27, 2021 at 1:30 PM
    • other Robots
  • KUKA : Part Presentation Vision *Correction*
    • SU05LLY
    • November 30, 2020 at 1:44 PM
    • KUKA Robot Forum
  • $JOINT_OFFSET linear axis
    • JuEdir
    • May 29, 2020 at 11:35 AM
    • KUKA Robot Forum
  • Touch Sensing RARCWMDP & #ARC_WMCV commands
    • SAQER
    • September 11, 2019 at 12:23 PM
  • Offset, PR[x] behavior
    • arikrundquist
    • June 25, 2019 at 12:43 AM
    • Fanuc Robot Forum
