I have been trying to use the Plugin Specific Alarm messages for Fanuc CRX from Karel programs.
The problem is that even though when building the plugin I can see that the plgalm.dat file is created, when I run the application and I encounter an error I do not see the defined error messages. I only see PLUG-001 [001], even when the format parameter is set to 0, in which case the error number [001] should not even appear in the error message, to my understanding.
I've tried with both directly passing error message text in the IPL_ERPOST function with "%s" defined in the plgalm.dat, as well as passing a NULL string in the IPL_ERPOST function and instead defining the error message in the plgalm.dat file.
As per plugin manual, my robot is above V9.40P/06 SW version requirement.
I would appreciate any guidance, or working examples of the Plugin Specific Alarm Messages being used.
