Hello All,
I hope you have good time, i have one refurbished Kuka Robot KRC1 with KVR150 running KSS 4.1.7 SP05.
right now I'm trying connect device net to MFC card to enable use I/O. but seem to be i have problem either with configuration or with driver version.
this is the error i get after reconfiguring the Devicenet.
"Configuration Error I/O driver DNDRV"
i have check similar threads similar to this one , as found most of these issue due to missing wiring ,matching Baudrate parameter or IOsys configuration.
problem with in/out ports Kuka KRC2
I would like to share some details about this issue:
1-I'm using Wago 750-306 with one input and one output module. i have used 120ohm resistor on both sides and current value is ~60ohms over the CAN L and Can H.
voltage with reference to ground is ~2.2V and ~3.6V. i have powered up Wago with 24V from the computer power supply, also connected ground for shield terminal.
also i have set dip switch to match the files configuration.
https://ibb.co/nL14mKc
after wiring all. i still did'nt get the connect LED lit on.
2- for the robot part file configuration:
i have attached Iosys and Devnet after editing and matching the MACID 5 and Baudrate 500.
3- after trying to use reconfiguration i get this error
I appreciate your help!! and i hope i didn't miss any information you might need
here are the file.
https://www.mediafire.com/file/3uenftfph…devnet.ini/file
https://www.mediafire.com/file/ergzmklbh2ziajo/dn2drv.o/file
https://www.mediafire.com/file/bgubvfe1sneb2ga/dndrv.o/file
https://www.mediafire.com/file/hxbm9mpor…/iosys.ini/file
https://www.mediafire.com/file/3zvzx6jch…/slave.ldb/file
" class="messageFloatObjectLeft">
devnet
[krc]
debug=0
baudrate=500
LOGFILE=1
[1]
macid=5
iosys
; IOSYS.INI - Configuration file for the IO-System
; For configuration help go to the end of this file.
[CONFIG]
VERSION=2.00
[DRIVERS]
;MFC=0,mfcEntry,mfcdrv.o
;INTERBUS=1,ibusInit,ibusdrv.o
DEVNET=2,dnInit,dndrv.o
;BOSCH=3,boschInit,boschdrv.o
;PERCEPTRON=4,percInit,percdrv.o
;SBIP=5,sbipInit,sbipdrv.o
;FIPIO=6,fipioInit,fipiodrv.o
;PROFISL=7,pbslInit,pfbsldrv.o
;PROFIMA=8,pbmaInit,pfbmadrv.o
;RIO=9,rioInit,riodrv.o
;LIBO=10,liboInit,libodrv.o
;PBMASL=11,pbmsInit,pfbmsdrv.o
;DNSC1=12,dnsc1Init,dnsc1drv.o
;DNSC2=13,dnsc2Init,dnsc2drv.o
;DSEIO=14,dseIoInit,dseiodrv.o
;INTERBUSPCI=15,ibsCPPciInit,ibpcidrv.o
;CNKE1=16,cnke1CPInit,cnke1drv.o
;DNSC3=17,dnsc3Init,dnsc3drv.o
;DNSC4=18,dnsc4Init,dnsc4drv.o
;DNSC5=19,dnsc5Init,dnsc5drv.o
;DNSC6=20,dnsc6Init,dnsc6drv.o
;CNKE2=21,cnke2CPInit,cnke2drv.o
[MFC]
INW0=0 ;$IN[1-16]
OUTW0=0 ;$OUT[1-16]
OUTW2=2 ;$OUT[17-32]
[INTERBUS]
;------- Inputs ---------
;Slave Inputs
INW50=896 ;$IN[401-416]
INW52=898 ;$IN[417-432]
INW54=900 ;$IN[433-448]
INW56=902 ;$IN[449-464]
;------- Outputs --------
;Slave Outputs
OUTW50=896 ;$OUT[401-416]
OUTW52=898 ;$OUT[417-432]
OUTW54=900 ;$OUT[433-448]
OUTW56=902 ;$OUT[449-464]
[DEVNET]
INB0=5,0,x1 ;$IN[1-8]
OUTB0=5,0,x1 ;$OUT[1-8]
[BOSCH]
INW64=0 ;$IN[513-528]
OUTW64=0 ;$OUT[513-528]
OUTW66=2 ;$OUT[529-544]
[PERCEPTRON]
INW68=0 ;$IN[545-560] X
INW70=2 ;$IN[561-576] X
INW72=4 ;$IN[577-592] Y
INW74=6 ;$IN[593-608] Y
INW76=8 ;$IN[609-624] Z
INW78=10 ;$IN[625-640] Z
INW80=12 ;$IN[641-656] A
INW82=14 ;$IN[657-672] B
INW84=16 ;$IN[673-688] C
INW86=18 ;$IN[689-704] ERG
OUTW68=0 ;$OUT[545-560] model, partner
OUTW70=2 ;$OUT[561-576] color, pointnr
OUTW72=4 ;$OUT[577-592] phase, fixture, command
OUTW74=6 ;$OUT[593-608] wrist angle roll
OUTW76=8 ;$OUT[609-624] wrist angle roll
OUTW78=10 ;$OUT[625-640] wrist angle pitch
OUTW80=12 ;$OUT[641-656] wrist angle pitch
OUTW82=14 ;$OUT[657-672] wrist angle yaw
OUTW84=16 ;$OUT[673-688] wrist angle yaw
[SBIP]
INW0=0 ;TASK READ : $IN[1-16]
INW2=2 ;MMI READ : $IN[17-32]
INW4=100 ;KEY READ : $IN[33-48]
INW6=4 ;RESULT1 : $IN[49-64]
INW8=6 ;RESULT2 : $IN[65-80]
INW10=8 ;RESULT3 : $IN[81-96]
INW12=10 ;RESULT4 : $IN[97-112]
INW14=12 ;RESULT5 : $IN[113-128]
INW16=14 ;RESULT6 : $IN[129-144]
INW18=16 ;RESULT7 : $IN[145-160]
INW20=18 ;RESULT8 : $IN[161-176]
INW22=20 ;RESULT9 : $IN[177-192]
INW24=22 ;RESULT0 : $IN[193-208]
OUTW0=0 ;TASK WRITE : $OUT[1-16]
OUTW2=2 ;MMI WRITE : $OUT[17-32]
OUTW4=100 ;KEY WRITE : $OUT[33-48]
OUTW6=102 ;PARAM1 : $OUT[49-64]
OUTW8=104 ;PARAM2 : $OUT[65-80]
OUTW10=106 ;PARAM3 : $OUT[81-96]
OUTW12=108 ;PARAM4 : $OUT[97-112]
OUTW14=110 ;PARAM5 : $OUT[113-128]
OUTW16=112 ;PARAM6 : $OUT[129-144]
OUTW18=114 ;PARAM7 : $OUT[145-160]
OUTW20=116 ;PARAM8 : $OUT[161-176]
OUTW22=118 ;PARAM9 : $OUT[177-192]
OUTW24=120 ;PARAM0 : $OUT[193-208]
[FIPIO]
[PROFISL]
INW0=0 ;$IN[1-16]
INW2=2 ;$IN[17-32]
INW10=4 ;$IN[81-96]
INW12=6 ;$IN[97-112]
OUTW0=0 ;$OUT[1-16]
OUTW10=4 ;$OUT[81-96]
OUTW12=6 ;$OUT[97-112]
[PROFIMA]
[RIO]
[LIBO]
[PBMASL]
[DNSC1]
[DNSC2]
[DNSC3]
[DNSC4]
[DNSC5]
[DNSC6]
[DSEIO]
INDW0=0 ;$IN[1-32]
OUTDW0=0 ;$OUT[1-32]
[INTERBUSPCI]
;Slave Inputs
;Slave Outputs
[CNKE1]
;=ConNo, additional offset,xSize
[CNKE2]
[END SECTION]
