We are planning to buy MFC2 board with model 00-108-766, but the suppliers have suggested me to buy model00- 123-879. Is this card the right replacement in our current system? And does it work without problems or not? By the way, our controller type is KR C2 and MP1 type.
Replacement type of MFC2 Board
- Majid Hd
- Thread is Unresolved
never heard of 766-108-00. that is wrong article number and it seem to be backwards. do you mean 00-108-766? that would be a valid format and article number for MFC2 (ISA port).
and what is 123879? do you mean 00-123-879? that too is MFC2.
dear Panic,
Yes, you wrote the correct format of the article. My question is, is it possible to use 00-123-879 instead of 00-108-766?
Apparently the suppliers are unable to supply 00-108-766.
KRC2 is discontinued and this is older variant too, so finding spares can be a challenge. normally higher grade cards (higher feature) can be used in place of the lower one. i would just contact KUKA for clarification.
Hi Majid Hd,
I have 00-108-766 available in stock if you would prefer to replace with the exact model.
https://globalrobots.com/mfc2-kuka-control-signal-board-non-ed05.html
Thank you
Lianne
The difference is in DSE-IBS board the first has 3.02 the second c33 the
c33 is more recent and works with newer kss (v5.6.12).
I have also a modded kss version (v5.4) that works also with DSE-IBS 3.02
