We have purchased a new welding robot setup, it consists of an irb 2400L with s4c+ controller. It has a torch cleaning station and a bullseye with it.
I have a good deal of experience working with these robots, however I have never used a bullseye before and am struggling to set it up. The company we bought it from said the bullseye was already setup however I cant see any menus or routines to do with it within the robot system.
I have tried to follow through the manual to set it up. The manual I have been using is for BullsEye 7.0. I have run through the software installation process and got to software setup and this is where I get my first problem. Below is the extract from the manual, It tells me to select view, Modules and then highlight BULLSEYE which I done however there is no SetupBullsEye routine appearing for me. so this is where I get stuck.
Software Setup:
Prepare the robot, the torch and BullsEye® for use. With the Program Window visible on the
Teach Pendant, select the VIEW Menu Key, select “Modules”, highlight BULLSEYE and press
ENTER. Now highlight the routine “SetupBullsEye” and press ENTER. Press the TEST
Function Key. With the robot ready to operate and the enabling devise activated, you may
begin the program by pressing the START Function Key.
I have tried contacting the company we bought it from however they said they don't know what is going on and suggested I restored the original backup they sent with the robot and try again. I done this with no difference.
Anyone any ideas to what is going on, am I not doing something correctly or have I missed something?
Again I have never used bullseye before so I am only going off what the manual is telling me.
