I want to trigger some time critical signals during the CP movement of my robot. Upon looking into AS language manual, I noticed the command MVWAIT that can be used to trigger signals when the robot reaches a certain distance before the target pose.
For example:
LMOVE pose1
MVWAIT 10mm
SIGNAL 500 ;This will turn signal 500 to high when to robot is 10mm away from pose1
However, I would like to trigger a signal after the robot has travelled a specified distance. Basically something similar to MVWAIT but instead of measuring the distance from the target (pose), I would like to measure the distance from the start of the movement.
Is there anyway to do such an operation?
My controller type is E controller.
Thank you in advance for your help.
