I wanted to use the movC instruction to make a circle, so I did it as below but the transition from p4 to p5 made me a straight line?
what happens when i make a wheel and give a lot of movc points? the circle will cease to be perfect? the segments between the points should be equal?
with curve and using movS should the line segments between points be equal?
