Need help with position variable
2ant -
May 27, 2023 at 12:05 PM -
I am ashamed, i took the line of code from HERE thinking that the syntax was fine but the multiplication at the end was not !
panic mode
May 27, 2023 at 1:16 PM Approved the thread. -
Quote
GO[1]=($SCR_GRP[1].$MCH_POS_X*10)
I just copied your code, and it works .... ?!?
Weird, for me the error was gone when i deleted the *10.
Turns out what i needed was the angles.
Here is what i used:
How do you enter the value ($SCR_GRP[1].$MCH_POS_X * 10) into the TP program?
Add instruction 'parameter' and fill in the parameter you want to use.
