Programing interrupt
  • hossein fallah
  • May 23, 2023 at 12:37 PM
  • hossein fallah
    29
    Hi everyone
    I'm having a problem that is hard to explain but I'll try my best
    I'm using a kr 16 krc2 for preparing box for packing our products
    I've wrote a program with interrupt that triggers with a OP sensor
    I defined two points that between these points When robot reaches to box, sensor triggers the brake and resume to the next act which is vacuum and some motions
    Problem is OP sensor needs to be active after interrupt off or brake and resume sub program. If sensor is not active robot stops with error. "shot 4"
    Is there anything wrong with my program that needs fixing or this is how interrupt works ?
    Images
      • 35.67 kB
      • 360 × 770
      • 9
      • 19.74 kB
      • 360 × 770
      • 8
  • Go to Best Answer
  • hossein fallah
    29
    • May 23, 2023 at 12:38 PM
  • hossein fallah
    29
    • May 23, 2023 at 12:45 PM
    Images
      • 230.46 kB
      • 1,920 × 896
      • 10
  • Roland Keller
    5
    60
    • May 23, 2023 at 12:58 PM
    • Best Answer
    DEF Carton()
       $Advance = 0
       Interrupt ON 15
       LIN
       LIN
    END
    DEF tdh()
       BRAKE
       WAIT SEC 0.5
       INTERRUPT OFF 15
       RESUME
    END
  • hossein fallah
    29
    • May 23, 2023 at 1:59 PM
    Quote from Roland Keller
    DEF Carton()
       $Advance = 0
       Interrupt ON 15
       LIN
       LIN
    END
    DEF tdh()
       BRAKE
       WAIT SEC 0.5
       INTERRUPT OFF 15
       RESUME
    END
    Thank you so much
    Problem solved
    :thumbs_up:
Similar Threads
  • Software Request to KUKA - the robot forum bugs and wish list
    • Werner Hampel
    • August 17, 2019 at 10:37 AM
    • KUKA Robot Forum
  • Kuka Interrupt not getting called
    • programmer29
    • June 7, 2021 at 8:37 AM
    • KUKA Robot Forum
  • Constant speed in aut mode
    • hossein fallah
    • May 21, 2023 at 3:43 PM
    • KUKA Robot Forum
  • Bit of a coding Conundrum
    • Ash
    • January 31, 2022 at 6:25 PM
    • KUKA Robot Forum
