Tiny Industrial robots
  • Reckless
  • May 21, 2023 at 12:53 AM
  • Reckless
    104
    Are there any tiny industrial robots like this size? Thinner/lighter is better but more importantly FASTER.
    SkyeFire
    1,059
    9,450
    • May 21, 2023 at 8:29 PM
    Maybe wafer-handling robots from the semiconductor industry? Whatever you're looking for is going to be a very niche product. In industrial robotics, most of the high-speed/low-payload work is dominated by Delta robots like the ABB FlexPicker.
  • loopindex
    60
    • May 21, 2023 at 9:53 PM
    The only robot I can think of (besides from what SkyeFire above suggested) is ABB’s kind of new IRB 1010. It’s small and neat as hell. :grinning_squinting_face:
  • Nation
    Typical Robot Error
    551
    1,932
    • May 22, 2023 at 1:00 AM
    There is the the meca 500.
  • PnsStarter
    94
    336
    • May 23, 2023 at 6:19 PM
    There is also the (amazing) MotoMini:
    MotoMini Small 6-Axis Robot | Yaskawa Motoman Robotics
    Files
    MotoMini.pdf 595.33 kB – 6 Downloads
    Backdate/TP-Tools: A small collection of tools that simplify the commissioning and programming of Fanuc robots. (github.com)
  • Reckless
    104
    • May 24, 2023 at 6:35 AM
    Those are all nice robots. Each has something nice about it. Wafer robots are also an idea like brooks automation cobot style. A fast industrial lightweight cobot is what I'm after.
    Would it be cheaper to build a custom robot based off the ultraarm design but using faster nema motors? The parts look so simple it could be 3d printed but my main issue is speed. How many motors does it have? 3?
    SkyeFire
    1,059
    9,450
    • May 25, 2023 at 1:37 AM
    Quote from Reckless
    Probably not possible. One of the defining characteristics of a Cobot is low speed, because even for a small robot, inertia can still be injurious (or even lethal). If you want really high speed (you keep saying "fast", but not defining any usable numbers), you're probably only going to get that from a standard non-Collaborative robot.
  • Reckless
    104
    • June 15, 2023 at 8:11 PM
    This comes close, still wishing for smaller and cheaper (ABB is synonymous with rip off to me). It still weighs 29lbs.
    specs
    I may get the Dorna 2 as it weighs 8lbs and ~90% cheaper. Any thoughts?
    panic mode
    1,293
    13,122
    • June 15, 2023 at 9:41 PM
    it is only 5 axis but it does look interesting, have not seen programming language. interfacing seem to be limited to built in 16+16 IO and raw TCP - there is no mention of any fieldbus. structure is built from parallel flat sheets which makes easy access to the inside but this also has limited structural integrity. since arm is low power it is unlikely to self destruct but things are different if someone bumps into it - the flat sheets are easy to bend so at the very least accuracy would be gone.
    but although arm itself is not powerful (and therefore not really dangerous), the construction was gears and pulleys exposed and that would make them a hazard to not careful finger. interesting thing is that distance is measured in inches.
  • Reckless
    104
    • July 4, 2023 at 6:18 AM
    Very interesting post about their design philosophy that seems very deeply thought out:
    belt stepper drive vs harmonic drive ac servos
    It seems to make sense to me but non intuitive unorthodox solution. Would love to hear what robot experts have to say.
  • saberdud
    46
    • July 14, 2023 at 6:17 PM
    • #11
    I read the article you posted, and I agree with all of their reasoning for their size of robot. The stepper motors they use pack a lot of punch for their size, but aren't really a good use for industrial sized robots. for larger robots, you want absolutely no backlash, as that puts the weight of the robot on the motors and it introduces a lot more stress. The stepper motors in their robots will not really care about that because the weight of the robot is so low.
  • Reckless
    104
    • August 2, 2024 at 5:01 AM
    • #12
    Quote from saberdud
    I believe their newer models have absolute encoders and are heavier with larger payloads. I am very fascinated with this robot due to its lightweight and trying to see how to reduce weight further. I bought this one with rail kit for packaging operation:
Similar Threads
  • Advice for beginners in Robotics
    • luciagege7
    • May 15, 2023 at 2:44 PM
    • General Discussion of Industrial Robots Only
