Searching for Direct Replacement Bolts from Fanuc?
  • alive15
  • May 18, 2023 at 6:19 PM
  • alive15
    15
    161
    Good morning guys, I'm looking for the direct replacement bolts from Fanuc? We will be swapping out a reducer and I wanted to replace all bolts, but Fanuc did not have these in stock. I wanted to purchase from McMaster, but not exactly sure what the direct replacement is? Here are the Fanuc part #s:
    A6-BA-8X16 cap screw
    A6-BA-8X25 cap screw
    Thanks!
  • Go to Best Answer
  • HawkME
    570
    3,269
    • May 19, 2023 at 2:59 AM
    Can you take one out and measure it? Probably just a regular metric M8 bolt.
  • Lerak
    203
    • May 19, 2023 at 4:10 PM
    Standard Metric but probably a grade 10 or 12
    If it starts well the first time, you have not checked all !
  • Skooter
    172
    2,055
    • May 20, 2023 at 11:47 PM
    • Best Answer
    91290A418
    91290A432
    Order the washers from Fanuc
    Don't forget the 518, 75125A66
    I like my Craftsman ratcheting digital torque wrenches that readout nm
  • ROBOT_G
    23
    241
    • May 25, 2023 at 12:06 AM
    some additional info
  • Skooter
    172
    2,055
    • May 25, 2023 at 3:37 AM
    I always use the numbers provided by Fanuc. There some items that use nonstandard torque; draw bolts and draw nuts on motor shafts are good examples.
  • neighbour1
    44
    405
    • May 25, 2023 at 12:43 PM
    Quote from alive15
    Thanks!
    What's the robot type and axis?
  • Bolts
