speed of movement from socket communication
  • This is the program that I wrote for the movement of Fanuc robots by Karel program.
    Firstly, the connection was examined without any movement of the robot (the “MOVE_G” program which is related to the teach pendant program at this step was blank, So I just wrote the position register without any movement ). The results were completely satisfactory: 7000 lines were sent and received in one minute.
    For the second step, I wrote the "L @ PR [80] 250 mm/sec CNT 100" in the teach pendant inside 'MOVE_G' teach pendant program, in order to control the motion of the robot with respect to the PR [80] . The results were disappointing, and the number of lines sent and received was reduced from 7000 to less than 100 lines as soon as I wrote the above code. The test conditions were the same except that "L @ PR [80] 250 mm/sec CNT 100 " was added to the 'MOVE_G' teach pendant program. I do not know what is the reason for reducing the speed of the connection when I am activating the movement.
    I wrote both Python and Karel code as below.
  • MOM
    Approved the thread.
  • Hi MohammadReza
    Quote
    CALL_PROG('MOVE_G', prog_index)
    you are calling the program.
    So inside your loop every time you CALL the TP-Prog it will be executed!
    In your case
    "L PR [80] 250 mm/sec CNT 100"
    will be executed (move the robot).
    Afterwards(!!) the Karel-Prog will continue....
    ::: Keep in mind, that it's a good idea to do error handling.
    Like checking you status var
  • Dear PnsStarter ,
    My problem is not about occurring errors. The code that I wrote above is running perfectly without any errors. So error handling is not an issue in my code.
    The problem is that when I am writing on TP this line "L @ PR [80] 250 mm/sec CNT 100" (I attached the photo below) the speed of sending and receiving data is reduced drastically and the robot is lagging instead of continuous movement.
    u8cz9fa86
  • "L PR [80] 250 mm/sec CNT 100"
    This is the answer to your question, i think.
    The code runs synchronously!!
    In this case you should run it asynchronously...
    (different tasks).7
    That means you need to adapt your two programs to asynchronous processing....
    Quote
    And it is always a GOOD idea to do some kind of error handling.
    best regards
