Data exchange between GOT2000 panel and robot
  • Hi all, I need to data exchange between robot and GOT panel. Especially I need send string from GOT panel to robot. I need it for save recept name in robot.
    How to do it ?
    Thank you for advice
  • I use for HMI panel GOT2000, GT27-VTBA and Robot RV-6SD, connected via FTP cable (MITSUBISHI ELECTRIC gateway), Ethernet multi protocol. I normally communicate using M_In/Out16 instruction, but I need to send the string. I made a script that sends the string character by character, but that's not a good solution.
    Do you have a idea how to do it ?
  • if possible i would just send numbers and do something like this
    (pseudo code incoming)
    select M_in(numberFrompanel)
    case 1
    callp "jobYouWant"
    break
    case 100
    callp "lastJobYouWant"
    break
    end select
    iirc string caused me some headaches in the past, so i covardly find my peace in number sending
  • You can also put the string on GD devices of the GOT and copy it via a script.
    [w:U3E0-10702]=105; //Function No=Write position value �iASCII)
    [w:U3E0-10703]=[w:GD1303]; //Slot No
    bmov([w:GD1310],[w:U3E0-10710],8); //Variable Name
    set([b:U3E0-10700.b0]); //Request for variable operation ON
