sensitiv pos setting kuka krc2
  • paulfile
  • April 29, 2023 at 6:59 AM
  • paulfile
    64
    hi , firstly ı make save the points to the robot. But ı need a one axis sensitiv setting. I need a motion just 2 mm in z axis but all program point . How can make this ?
    Thank you
  • hermann
    407
    2,611
    • April 29, 2023 at 7:58 AM
    Change the Z coordinate of the base where the points are teached and used for the movement.
  • paulfile
    64
    • April 29, 2023 at 8:23 AM
    how do ı do this ?
    For example my line this
    LIN P246 Vel=0.2m/s CPDAT223 Tool[4]:A Base[0]
  • hermann
    407
    2,611
    • April 29, 2023 at 10:45 AM
    Oh, you use Base No. 0. That's not good.
    You always should use a base not zero, as you can't change base 0 (except you change $roboroot, but that would be a bad idea in your case).
    So, change all movements to, let's say base no 1. Where base_data[1] is $nullframe.
    Then change base_data[1].z to 2.0.
