  4. Kawasaki Robot Forum
using BITS32 to send joint positions over EtherCAT fieldbus
  • Vaibhav Shah
  • April 28, 2023 at 10:21 AM
  • Vaibhav Shah
    8
    I am writing a PC program that checks the robot joint positions every scan and sends it over EtherCAT to my PLC over a 32bit address. My robot is BX200L-A001 and my controller is E02. This is the snippet of code I am using inside an infinite WHILE loop:
    HERE #pose
    DECOMPOSE joints[0] = #pose
    @Temp = INT(joints[0]*1000) ; <--- This is giving me an error "(P0115) Illegal Function"
    BITS32 101, 32 = @Temp
    I am not using 16 bits to send the joint values since I want a precision of 3 decimals and also I have a 7th axis (positioner) that can have joint values in the thousands.
    Upon browsing here, I found a thread that says that BIT32 can only accept INTEGER values due to possibly a bug. For this reason, I am trying to convert the the REAL values from the "joints" array into integer and then passing that integer value to the BITS32 command. I am getting the "Illegal Function" error on the marked line above. I am assuming that the return type of the INT() function is still a REAL and not an INTEGER. How do I convert a REAL value in the joints array to an integer that can be passed to the BITS32 command?
  • Go to Best Answer
  • HawkME April 28, 2023 at 10:46 AM
    Approved the thread.
  • kwakisaki
    694
    4,770
    • April 29, 2023 at 11:31 AM
    What was mentioned in that thread about a 'bug' was a loose statement I made without cause.
    I am pretty sure converting real to whole number may not be possible.
    Even though the real can be changed to an integer value via INT command, I am 100% sure it still remains as a real variable and cannot be transferred to a whole number to be used as @.
    A BX200 and you require 3 decimal places....... :hmmm:
    Strange you would need to monitor for that accuracy as the repeatable accuracy for that robot will never sit in a 3 decimal place arena.
    Anyway, like I mentioned, I don't think there is a solution for converting a real number to whole number in Kawasaki.
    I would contact Kawasaki directly for this and see if they do have a solution available.
  • Alexandru
    49
    407
    • May 1, 2023 at 4:03 PM
    You can create a TCP/IP with the PLC and send directly with a telegram the real value.
  • dm.bogachev
    45
    86
    • May 1, 2023 at 8:03 PM
    • Best Answer
    I have a code example for sending 32-bits numbers, but you should know that it will be correct only for the first 7 digits. (According to the manual)
    .*Wichtiger Hinweis:
    .*Bei Variablen vom Typ "REAL" werden nur die ersten 7 Stellen einer Zahl beruecksichtig!
    .*Variablen vom Typ "REAL" koennen Zahlen im Bereich von -3.402823*10^38 bis +3.402823*10^38 darstellen.
    .*Da bei 32BIT eigentlich Variablen vom Typ "INTEGER" verwendet werden, welche bis zu 10 Stellen einer Zahl
    .*berueksichtigen koennen, muss der Zahlenbereich unter Verwendung dieses Beispiel entsprechend limitiert werden.
    .PROGRAM main()
    ;Real in 32Bit umwandeln
    ;Im folgenden Beispiel werden die Eingange "1001-1032" ausgelesen und das Ergebnis als Dezimalwert in die Variable "ergebnis" geschrieben.
    startbit = 1001
    CALL bits32_to_real(startbit,ergebnis)
    ;32Bit in Real umwandeln
    ;Im folgenden Beispiel wird der Dezimalwert von "wert" in Binaer umgewandelt und auf die Ausgaenge "1-32" geschrieben.
    wert = 1234
    startbit = 1
    dezimal = 2
    CALL real_to_bits32(wert,startbit)
    .END
    .PROGRAM real_to_bits32(.value,.startbit)
    ;.value    = Dezimalwert
    ;.startbit = Startbitnummer
    If .value < 0
        SIGNAL (.startbit+31)
        .value = -.value-1
            FOR .i = 4 TO 1 STEP-1
                .byte[.i] = INT(.value/(256^(.i-1)))
                .value = .value - (.byte[.i]*(256^(.i-1)))
            END
        BITS .startbit,8      = .byte[1]
        BITS (.startbit+8),8  = .byte[2]
        BITS (.startbit+16),8 = .byte[3]
        BITS (.startbit+24),7 = .byte[4]
        FOR .i = 0 TO 30
        .sigtemp = .startbit+.i
        SOUT .sigtemp = -.sigtemp
        END
    ELSE
        SIGNAL -(.startbit+31)
            END
    END
    .END
    .PROGRAM bits32_to_real(.startbit,.value)
    ;.value    = Ergebnis als Dezimalwert
      .byte[1] = BITS(.startbit,8)
      .byte[2] = BITS((.startbit+8),8)
      .byte[3] = BITS((.startbit+16),8)
      .byte[4] = BITS((.startbit+24),7)
      IF SIG(.startbit+31) THEN
        .value = (-2147483648+.byte[4]*2^24+.byte[3]*2^16+.byte[2]*2^8+.byte[1])
      ELSE
        .value = (.byte[4]*2^24+.byte[3]*2^16+.byte[2]*2^8+.byte[1])
      END
    .END
  • dm.bogachev
    45
    86
    • May 1, 2023 at 10:22 PM
    Also, you can send in one 16-bit word integer part and the other 16-bit word - fractional part and then calculate the result on PLC
  • Vaibhav Shah
    8
    • May 2, 2023 at 9:00 AM
    Quote from dm.bogachev
    .PROGRAM main()
    startbit = 1001
    wert = 1234
    startbit = 1
    dezimal = 2
    .END
    If .value < 0
        .value = -.value-1
            END
        FOR .i = 0 TO 30
        END
    ELSE
            END
    END
    .END
      ELSE
      END
    .END
    Thank you so much for this code! I will try and run it today on the robot!
  • Vaibhav Shah
    8
    • May 2, 2023 at 12:22 PM
    Quote from kwakisaki
    Ahh my apologies for the "bug" statement.
    The reason why I want to have a 3 decimal accuracy is because I want to replicate the position of the robot in our custom software. Even if I lower my resolution to 2 decimal places, the question of JT7 axis still remains because for a linear track of 10m, the max position is 10000.0 mm. So 16 bits would not be sufficient in the future should a customer decide to purchase a robot with 10m track.
  • E controller
