KUKA and EUROMAP67
  • BOTja
  • April 24, 2023 at 9:06 AM
  • BOTja
    36
    So I'm setting up the I/O for a KUKA Robot that I will need to program in order to communicate with a IMM using EUROMAP67, but I can't figure out how to add the EUROMAP67 protocol to the WorkVisual project. I might need a DTM file so I can add the device, but I have no idea if that's all I need or how to get that DTM file, so I was wondering if anybody has done this before, because all I can find about E67 is done with other robots or gives no information about how they made the setup in the robot.
  • HawkME April 24, 2023 at 11:02 AM
    Approved the thread.
  • IlFincoITA
    204
    • April 24, 2023 at 11:37 AM
    EUROMAP67 is an interface that you need to built using both safety and Input output signals. All of them will be wired to a double connector of 25 pins going from Robot to the Moulding Machine and 25 pins coming from the Moulding Machine to the robot.
    No DTM is necessaty to do that...
  • BOTja
    36
    • April 24, 2023 at 11:48 AM
    Quote from IlFincoITA
    That I know, I have the I/O ready for that, but how do I connect an input from the Robot to be an input from the connector of the EUROMAP cable? how do I tell the robot that, for example, those 25 inputs will be from $IN[100] to $IN[124].
  • IlFincoITA
    204
    • April 24, 2023 at 11:59 AM
    For the safety signals they must be connected to a safety device. Have you got something connected to the extension BUS (SYS-X44)? Usally I put there the EK100 (BECKHOFF) EtherCat coupler and from there a bunch of Inputs and outputs with EL1809 and EL2809 (BECKHOFF terminals). Those terminals have an ESI file description that can be mapped into workvisual.
  • BOTja
    36
    • April 24, 2023 at 12:07 PM
    All the safety will go to a PLC as it will be the one in charge for the safety of the hole project.
    The thing is that I don't have the robot here with me yet, I'm trying to set up everything so when it arrives I can make it work as soon as possible, Kuka will connect the E67 card to the robot and so but, I wanted to have the I/O mapped before having the robot.
    I have no idea where is KUKA going to connect the EUROMAP67 card or whatever it uses, I have never used that protocol before, but it seems that I will need to wait until the robot arrives.
  • IlFincoITA
    204
    • April 24, 2023 at 12:26 PM
    I see... if you buy a built in E67 you will find the E67 connector ready to be used. I only know that there is a tecnology cabinet wich has onboard the E67.
    Files
    MA_KR_C4_SC4_1_AS_PS_E67_Rehau_en.pdf 3.3 MB – 43 Downloads
  • BOTja
    36
    • April 25, 2023 at 8:08 AM
    Alright, so all I have to do is import the project from the robot into WorkVisual and I will find where to map the I/O of E67 isn't it?
    I can't find anything to prepare it before, but I guess I can wait until the robot arrives.
  • imm
  • euromap67
  • EtherCAT
