Hi any help is appreciated I run 2X KR 8 R2100 arc HW on KRC 4 KSS 8.5.8 software. R1 and R2
The issue I'm having is once I've taught the point and run a test in T2 mode its all good does as should no problem, but when I have it complete and run in auto mode the placement points with R2 is off by 20-30mm but the weld points with R1 are correct.
So I go back and recheck all is well re-teach points with touch up just in case and again run in T2 mode welds are perfect placement perfect back into auto mode all placements are off again??
