Dat file not showing up
  • AD3MIN
  • April 20, 2023 at 3:38 PM
  • AD3MIN
    57
    hi all,
    I am new to Kuka, I have KUKA KRC2 with Version V5.5.16.
    Dat files are not showing up in the program. The filter is showing 'user'. How to enable the filter to 'DETAIL'?
    The only edit option is at the top left near Configure. But there is no filter option in it.
    cheers!
  • panic mode April 20, 2023 at 3:41 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum KUKA Robot Forum.
    panic mode
    1,280
    13,085
    • April 20, 2023 at 3:42 PM
    you need to login as Expert, then you should be able to change filter settings and see all files. don't recall much from KRC2 but it should be in the first menu
  • AD3MIN
    57
    • April 20, 2023 at 4:07 PM
    Thank you for your reply.
    I logged in as expert as you suggested. But still cant find the filter option
    I have attached the images of the Hmi screen. Please have a look
    cheers!!
    panic mode
    1,280
    13,085
    • April 20, 2023 at 6:49 PM
    your image shows Edit menu. please check File menu, it is one on the left...
    SkyeFire
    1,052
    9,429
    • April 20, 2023 at 11:36 PM
    The other option is to highlight the module, as your photo shows, then push the right-arrow key. IIRC, that should open a sub-menu that will let you open the .SRC or the .DAT file.
    I also noticed that the "M" icon for your module also shows a tiny piece of chain -- that indicates that the module is linked to an active process, possibly the SPS background task. This can sometimes cause issues with opening and editing files. If you get a message that "file cannot be edited", this may be the cause.
    panic mode
    1,280
    13,085
    • April 21, 2023 at 2:04 AM
    pretty sure on the FILE menu of KSS 4x and 5x there is an option FILTER... should be a bit down (item 7 or 8).
    on even older KSS one could choose filter separately for robot and drives....
    FILE>ROBOT>0 (*.*)
    and
    FILE>DRIVES<0 (*.*)
  • AD3MIN
    57
    • April 21, 2023 at 3:19 PM
    Thanks guys. The suggestions you gave really helped me enabling the 'DETAIL 'option.
    File>filter>detail.
    cheers and have a great weekend!
Similar Threads
  • HIBERNATE - IS IT A PROBLEM FOR KRC4?
    • IlFincoITA
    • June 8, 2020 at 1:01 PM
    • KUKA Robot Forum
  • KRL Styleguide
    • Hes
    • October 29, 2022 at 1:10 PM
    • KUKA Robot Forum
  • Mapping I/O KRC4 | Get Current Cartesian Position
    • Lucasss
    • June 16, 2022 at 12:41 PM
    • KUKA Robot Forum
  • "Proper" way to write motion commands
    • mfpitts
    • May 17, 2022 at 8:46 PM
    • KUKA Robot Forum
  • Config.dat Joint Position Info Corrupted
    • farsided1
    • November 27, 2021 at 8:28 PM
    • KUKA Robot Forum
  • KRC2 $config.dat fail
    • Catalin Pop
    • August 20, 2020 at 1:18 PM
    • KUKA Robot Forum
  • KRC32 mas.dat
    • MechanikaEngineering
    • July 6, 2018 at 6:51 AM
    • KUKA Robot Forum
  • Variable Display
    • Ruddock984
    • June 5, 2020 at 4:01 PM
    • KUKA Robot Forum
  • Any Kuka KMP 1500 experts ?
    • SavageInT1
    • May 22, 2020 at 8:46 AM
    • General Discussion of Industrial Robots Only
  • Read all lines from .DT file with Karel
    • Darkbound
    • March 22, 2020 at 1:00 PM
    • Fanuc Robot Forum
