I'm trying to connect 2 NX100 robots via profibus using AB3601 slave card on one of the robots (the configuration for this card done from maintenance mode: adress node 2) and on the other robot AB3602 master card. I followed the instructions in the manual 164430-1: installed the card, start the robot in maintenance mode, installed the card here. It comes to using Anybus NetTool for Profinet: I followed the exact instructions from the manual but when trying to download the configuration i'm getting "error in communication with the hardware can't create transport path". I'm not sure if the cable is the issue (i tried using a rs232 serial cable female-female) from a pc running windows 10 and a serial port and also i tried reversing the connection between pins 2 and 3 (rx and tx) but no change in the situation. Also without connecting the cable the error log file from anybus tool looks exactly the same.
