KUKA ROBOT - General communication error by acessing controller
  • Zin1701
  • April 14, 2023 at 8:41 AM
  • Zin1701
    50
    Hi expert!
    i have a problem like this picture
    when i add option loadDetermination for workVisual, and then i deploy it to controller
    this error happens. but when i do the same thing with other kuka robots controller, nothing happen
    plz tell me how to deal with this error, thanks so much
  • Zin1701
    50
    • April 14, 2023 at 9:57 AM
    bonus: even when i just open the project and don't change anything, then i deploy. This error still happens
  • desertgiant
    52
    • April 14, 2023 at 10:54 AM
    Do you by any chance have a firewall pc configured ?
    Then the ports should be enabled in the firewall pc.
    Check xpert.kuka.com for the required ports specially for the workvisual communication.
  • Zin1701
    50
    • April 14, 2023 at 11:50 AM
    i found it . it's from date/time
    Images
      • 170.11 kB
      • 1,441 × 908
      • 63
  • Hes
    42
    243
    • April 14, 2023 at 7:55 PM
    had something similar once also, loading initial project from the controller saving it to a new name and trying to deploy it, just did not work. Installing the latest version of workvisual sorted it out for me.
  • xxperelkaxx
    5
    • June 4, 2023 at 8:54 AM
    Quote from Zin1701
    Hello Zin1701,
    I have the same situation. Could You tell me how did You fix it?
    Thanks in advance!
  • panic mode
    1,297
    13,141
    • June 5, 2023 at 2:30 AM
    Quote from Zin1701
  • xxperelkaxx
    5
    • June 5, 2023 at 3:19 PM
    Hello Panic Mode,
    I don't realy know what "from date/time" means. On the robot? Laptop? Something with WoV? Where to change and what?
    If You could give me a hint where to start looking.
    Thanks!
  • panic mode
    1,297
    13,141
    • June 5, 2023 at 4:39 PM
    i have not run into this issue myself but if i recall things can go weird with WoV when time is not set correctly at one or both side (my guess is robot). and that seem to be what Zin1701 was referring to same thing so check if the time/date is correct. to adjust time on KRC one must login and minimize HMI..
  • Zin1701
    50
    • June 5, 2023 at 5:40 PM
    Quote from panic mode
    that's it
  • xxperelkaxx
    5
    • June 8, 2023 at 9:18 AM
    • #11
    A okay just to set the time on the KCP.
    It's clear now.
    Thanks a lot!!
  • kuka communication
  • KUKA ROBOT - General communic
  • error communication kuka
