Wierd USB issues in KAREL
  • Hi all,
    so i'm writing a KAREL program of which part of it logs to a file on USB (UD1) if the user has selected choice to log.
    if the user HAS selected choice to log then the USB MUST be inserted for logging - if not the program must abort it's process
    so...
    OPEN FILE LOG_FILE('AP', fn)fstatus = IO_STATUS(LOG_FILE)
    fstatus is always zero whether USB plugged in or not
    so it was suggested to me to try opening the file read-only as that gives the correct IO status...
    OPEN FILE LOG_FILE('RO',fn)
    fstatus is zero if USB in and file already exists
    fstatus is 2014 if USB in and file doeasn't exist yet (FILE-014 File not found)
    fstatus is 2014 is USB is not in (FILE-014 File not found)
    It seems there’s no difference between..
    1. “the file doesn’t exist because usb NOT plugged in” (2014) and
    2. “the usb IS plugged in but the file doesn’t exist on it” (2014)
    another suggestion was to use
    flist : ARRAY[2] OF STRING[40]
    FILE_LIST(fn, 0, 3, flist, n_files, fstatus)
    but similarly, fstatus is always 0 whether USB is in or not. Hmmmm….
    basically all i need is,..
    IF USB connected THEN
    append log file
    ELSE
    ABORT
    ENDIF
    Anyone have any ideas what's going on, or how to solve it?
    Any help would be extremey appreciated
    Chris
  • Place your Ad here!
  • HawkME
    Approved the thread.
  • Hi ChrisFS,
    I think the behavior, and the error messages are correct.
    Quote
    That the status is zero is ok, only when writing there is an error.
    We want to append text to the file, in 'AP' mode it doesn't matter if the file exists or not.
    And the second error is also correct.
    as you have written: 2014 -->FILE-014 File not found
    E.g. Windows would tell you in this case also "File not found"... and not "USB stick not inserted" :winking_face:
    You can evaluate the error when you write to the file and then set a status variable that tells you or the program that no USB drive is present.
    Alternatively you can use (from Karel manual)
    DOSFILE_INF('UD1:', DF_MANUFNAME, value, status)
    DF_MANUFNAME' vendor name
    value -->manufacturer name but not of interest here.
    check "status" ...
    But I strongly advise not to write a background program to monitor if the USB stick is inserted...
    best regards
  • hi PnsStarter,
    that's for the reply.
    OK, it was not working because i was using roboguide. sim gives 2014 for everything - duh!
    on the real robot, the correct status's are set.
    but....
    fstatus is always zero whether USB plugged in or not on sim and robot.
    No-one at our Fanuc contacts know why.
    OPEN FILE LOG_FILE('RO', fn)
    however, does give the correct status though. so this was used in the end (if anyone's insterested)..
    IF (fstatus = 0) OR (fstatus = 2014) THEN;
           IF (fstatus = 0) THEN;
                  -- log file exists..
           ENDIF
           IF (fstatus = 2014) THEN;
                  -- log file doesn’t exists..
           ENDIF
           CLOSE FILE LOG_FILE
           OPEN FILE LOG_FILE('AP',fn)
           IF fstatus = 0 THEN
                  -- write log file..
           ENDIF
    ELSE
           IF (fstatus = 2068) THEN;
                  -- usb not plugged in..
           ENDIF
    ENDIF
    CLOSE FILE LOG_FILE
    Cheers,
    Chris
  • From experience I know that appending to a file from karel can get very slow, especially when writing to usb.
    The karel interpreter seems to seek the length of the file after opening, to get to the end, and that's slow.
