I have downloaded mids routines and open them with notepad but if I want to make a modification how can I upload it to my dx200 controller
how to load and edit a routine downloaded from my dx200 controller?
- alejandrofts
- Thread is Unresolved
Fubini
Approved the thread. -
How did you download from controllers?
You can load those same as download method.
In the main menu, go to EX. MEMORY and there are LOAD and SAVE.
SAVE is to download from controller and LOAD is to load on the controller.
But if I load my file with the same name, does it replace the routine that I already have or create another one?
With loading jobs, it depends on a parameter, RS059. Depending on how it is set, the controller may overwrite or may give you an error.
If when you save or load a screen comes up asking for a forced execution the controller will overwrite the job. If you don’t see that screen you will either have to delete the job or rename it.
it is spot welding instruction is not load.
What instruction are you trying to load? Are both controllers set for the same application?
