KSS doesn’t load correctly
  • RoboCopo
  • March 29, 2023 at 1:12 PM
  • RoboCopo
    19
    Hello guys,
    when i downloaded update for KSS I minimized HMI and stopped the KRC module. When i turned off key switch and turned it back on it just loaded Windows Embedded CE 6.0. I would ask you for help because i tried multiple things and nothing changed. For drive it only shows NAND Flash drive.
    So if anyone encountered with this problem, please help!!
    Kind regards
  • kwakisaki March 29, 2023 at 1:17 PM
    Approved the thread.
  • panic mode
    1,297
    13,141
    • March 29, 2023 at 2:09 PM
    more info is needed. description sounds weird, that is not how KSS upgrade is performed
  • RoboCopo
    19
    • March 29, 2023 at 2:34 PM
    I wanted to upgrade KSS release from 8.2.6 to 8.5. Firstly i stopped the KRC on the minimized HMI (Windows), then i tried to setup the KSS 8.5 Relase. Then it showed it cant be set up and then i turned the switch off. When i turned it back on it just showed a startup KUKA picture and then directly went to Windows Embedded. So im really confused what have i done wrong.
    Kind regards.
  • panic mode
    1,297
    13,141
    • March 29, 2023 at 2:39 PM
    i m sure KUKA can help
  • RoboCopo
    19
    • March 29, 2023 at 2:46 PM
    Still thank you for help panic.
    Kind regards
  • panic mode
    1,297
    13,141
    • March 29, 2023 at 3:07 PM
    you are welcome
    proper way is to contact KUKA, share your system info (serial numbers, software versions, KRCDiag) and ask for quote.
    this is not just KSS, it is operating system (migrating from XP to Win7) and options. creating of new project, transferring programs and settings, hardware (firmware) update...
    SkyeFire
    1,061
    9,463
    • March 29, 2023 at 4:23 PM
    Quote from RoboCopo
    Where did you get this KSS release? Many KRC4s that shipped with KSS 8.2 may not be able to run 8.5. Also, what you describe is not the process for updating KSS. You must use a KSS Image from KUKA, deployed using a KSR USB stick. The KSR stick must be configured correctly, then the KRC rebooted with the KSR plugged into one of the KRC's USB ports. The KSR stick will wipe the KRC's hard drive and perform a factory reset, using the new Image.
    Obtaining correct KSS image from KUKA, using your KRC4's serial number, is critical, since attempting to install a KSS Image that is not correct for the hardware will likely destroy the KRC at the software level. The only way to recover from this would be to factory-reset the KRC, using KSR with either a KUKA factory Image, or a good Backup Image made with the KSR while the robot was still in good operating condition.
  • Hes
    42
    243
    • March 29, 2023 at 4:43 PM
    upgrading from kss 8.2 to 8.5 sounds like one hell of a step, i would be very surprised if hardware is compatible, not to mention windows.
  • panic mode
    1,297
    13,141
    • March 29, 2023 at 5:34 PM
    it is... and it should include firmware upgrade for all hardware, something only KUKA does.
    as far as KSS, Windows and KRC4 motherboards compatibility, SJX shared nice overview:
    KSS 8.6 - Roboterforum.de - die Industrieroboter und Cobot Community
    Guten morgen, Ich habe hier 20 KRC4 Steuerungen. Unsere Geschäftsführung sieht es vor alle Roboter auf den gleichen Softwarestand zu bringen. Einen Preis habe…
    www.roboterforum.de
    of course cost of software licenses is rather high and if you are lucky, you may get discount. otherwise, changing to a different major software version is a piracy.
  • MOM
    176
    7
    1,424
    • March 29, 2023 at 5:51 PM
    Changing from KSS 8.2 to KSS 8.5 is not an update. It is an upgrade and must be paid for.
    Normally KUKA check the exsting hardware and give you a price for the upgrade (software and needed hardware)
  • RoboCopo
    19
    • March 29, 2023 at 7:51 PM
    • #11
    Like i said im new to this, it was said to me to upgrade KSS Version so i tried my best but nobody told me all consequences that this may have. So I really thank you all for help.
    Kind regards.
  • MOM
    176
    7
    1,424
    • March 29, 2023 at 9:04 PM
    • #12
    Going from KSS 8.2 to KSS 8.5 the OS (WinXPe vs. Win7) and the KSS and additionally maybe hardware has to be upgraded!
    You should talk to the person who said that to you: check with kuka!
    Was there a specific reason for the upgrade or just wanted to have the latest version (which is actually not the latest version)?
    At the moment I am not really sure who of you violated the forums policy and should be banned
    You becausea asking
    or the second man ordering
    SkyeFire
    1,061
    9,463
    • March 30, 2023 at 12:14 AM
    • #13
    Quote from RoboCopo
    Kind regards.
    I can only conclude that whoever told you that is either incompetent, or was selling illegal copies of KSS.
  • RoboCopo
    19
    • March 30, 2023 at 7:39 AM
    • #14
    Like i said im really fresh with kuka i didnt know this kinda stuff. So yes ill tell him that this is not possible and show him the text’s that you all send so i have a proof. From now on ill only ask you guys.
    Kind regards.
  • Leon
    35
    5
    476
    • March 30, 2023 at 9:51 AM
    • #15
    Quote from RoboCopo
    Not a bad idea, but i would advise to ask kuka first. especially about stuff like this. asking costs nothing and in my experience they are always willing to give information if you ask.
    This forum has a lot of information and experienced people on it, but it is no replacement for kuka service.
  • MOM
    176
    7
    1,424
    • March 30, 2023 at 6:30 PM
    • #16
    Quote from Leon
    It was never the intention of this forum to replace kuka service!
    If you have a problem there are different ways to solve the problem:
    1- check this forum for already known problems and solved issues (if they marked solved and how)
    2- try to figure it out yourself - most of the time this will not work
    3- check with kuka (they will do the rest)
    This also works for all other robot manufacturers
    And this forum will not help to violate any copyright or license rules
Similar Threads
  • KRC4 KSS8.5.8 : PROGRAM NOT AVAILABLE
    • robotecnik
    • June 10, 2020 at 8:37 AM
    • KUKA Robot Forum
  • Krc4 With a non Kuka SSD
    • the leg
    • December 5, 2019 at 4:48 PM
    • KUKA Robot Forum
  • KSS 8.3
  • VKR 110 R3100
