I am facing with the problem of SRVO-105 . The controller is R30IA with M710IC robot . The controller doesn't have door switch.
No PLC and no external TBOP connections to panel board or e-stop board (all necessary jumpers are present). The robot was working till esterday.
When system powered on in auto mode everything seems to be normal, amplifier enabled and robot is ready to work, but after 2-3 minutes (it is random) the srvo-105 error showing up. With reset it is possible to eliminate it , but sometimes it is back immediately and some times after 1-2 minutes show up again. In manual mode the situation is same.
All recommended steps from trouble shooting manual was done ( panel board , e-stop board, amplifier were replaced , were taken from another working unit). The connectors on E-stop board , panel board and amplifier were checked. The cold start was done.
Nothing helped, the problem still exist.
Any suggestions or recommendations ?
Thank you in advance,
