Welding arc
  • iKSnIMAk
  • March 25, 2023 at 9:09 PM
  • iKSnIMAk
    24
    We have a problem with starting the KUKA stand.
    The robot is a KUKA KR6/2 control cabinet KRC-1 with a MERKLE PU 400 RS analog welder.
    It doesn't show any errors when connected.
    Only when we write a short program, the robot cannot ignite the welding arc.
    Any tips? :winking_face:
  • Go to Best Answer
  • massula March 25, 2023 at 9:10 PM
    Approved the thread.
  • MOM
    175
    7
    1,424
    • March 25, 2023 at 10:07 PM
    Yes,
    - make sure that Merkle is switched on
    - check cables
    - check i/o signal/state
    - check krl programme
    With all the given information it is impossible to make any suggestions!
    Can you provide some more useful information?
  • iKSnIMAk
    24
    • March 26, 2023 at 1:43 PM
    Quote from MOM
    Yes,
    - check cables
    Everything you write about is already checked!
    I wouldn't post without turning on the welder :grinning_squinting_face: :grinning_squinting_face: :grinning_squinting_face:
    The only thing you could expand on is the KRL program
  • MOM
    175
    7
    1,424
    • March 26, 2023 at 4:49 PM
    Was the system working before or is it a new setup?
    Do you use ArcTechAnalog (A10) or wrote the krl program yourself?
    Do you have something like cold and hot welding?
    What's about the welding parameter?
    Also pictures could help
  • SkyeFire
    1,051
    9,426
    • March 27, 2023 at 3:49 PM
    Quote from Kaminski
    What does this mean? Details matter.
    Does nothing happen at all? Is there an error message? If so, what is the error message?
    What command are you using to start the arc? With what signals? Are those signals changing state when you execute the command?
    What KSS version are you running? What KUKA-ARC version?
    Did you build this system, or buy it complete? Did it work before?
  • iKSnIMAk
    24
    • April 1, 2023 at 4:59 PM
    The case looks like this. The robot is connected correctly, all wires are operational.
    The previous owner cleaned it and I think that may be the problem.
    https://drive.google.com/file/d/1zO-8og111nCeDeuf1f2YzQ_LDli03sMV/view?usp=sharing
    https://drive.google.com/file/d/1wxIjGLSQ6cuoCuhBFadztlKXBTDJoGkW/view?usp=sharing
    https://drive.google.com/file/d/15vzNUmtDi-7h5sjRvbD2KsHRpZa-h0R-/view?usp=sharing
    https://drive.google.com/file/d/1O255AwbUKLO6EU--zdWKjxvd6eDVk5WY/view?usp=sharing
    Edited once, last by iKSnIMAk (April 1, 2023 at 5:14 PM).
    panic mode
    1,280
    13,082
    • April 1, 2023 at 6:07 PM
    Quote from Kaminski
    checked by someone inexperienced can mean things are overlooked or not checked at all. of all thing you said are checked, i only consider one to be true - Merle was turned on. there is no reason to doubt that one, but i see absolutely no evidence for other points to be checked in any way.
    if you check other threads you will see that most users start by stating that "they have checked everything". however the reason they come to forum asking for help is a clear indication that they did not check it or at least not the right things or not the right way... so as far as i am concerned they may as well have used city tour map instead of schematics and dowsing rod instead of DMM. maybe that puts some perspective on "details matter".
    so:
    how exactly did you check wiring? using what schematic? using what tools?
    how exactly did you check IO configuration? did you do IO check?
    how exactly is your program controlling welder? using what IOs?
    next:
    how is your German?
    33 = welder ok (not TRUE)
    34 = current ok (not TRUE)
    35 = water ok (not TRUE)
    36 = Crash contact (TRUE)
    so clearly either Welder is not connected, or connection is wrong or welder is not ready for whatever reason (check troubleshooting section of the welder manual)
    and how about this:
    it looks like robot is trying to start weld (output 33 is true). that of course is assuming that IO map is correct.
  • iKSnIMAk
    24
    • April 1, 2023 at 6:48 PM
    I'm just trying to solve a problem that robot tech support can't handle. it only transmits what the technical support page tells us. But this writing reassures me that the service doesn't know what it is doing and how to solve it 🥴
    Edited once, last by iKSnIMAk (April 1, 2023 at 7:28 PM).
  • MOM
    175
    7
    1,424
    • April 1, 2023 at 7:39 PM
    Do you have the user manual for the merkle?
    There should be a trouble shooting section and also a sequence diagram for comms
    I agree with panic mode
    Quote from MOM
    Yes,
    - check cables
    did you really checked everything
    I am just wondering to get "crash Kontakt" and not "stromquelle bereit"
    panic mode
    1,280
    13,082
    • Best Answer
    robot tech support cannot handle case with no info. same is here on this forum.
    to see what you have, YOU need to start digging deeper and sharing the findings. you provided next to nothing that could be useful.
    so far there is zero mention of wiring, welder parameter, welder configuration, welder state indicators, if the welder can be used manually (without robot) etc. you never shared link to the manual so here is one i found.
    same goes for robot - if you robot has some IOs at all, if they are operational etc.
    show us the configuration and mapping. this would be the top part if IOSYS.INI
    then we can see what device if any is using I/Os 33-36. for all we know, there may be no driver enabled.
    Files
    pu_400_dw.pdf 1.69 MB – 6 Downloads
  • MOM
    175
    7
    1,424
    • April 1, 2023 at 8:23 PM
    • #11
    @panic mode
    On the german site of manualslib I found the doc for MERKLE PU 520 RS (with Robot interface)
    In accordance to this manual
    Quote from Kaminski
    one reason could be: wrong program selected
    see
    pu_520_rs.pdf
    (in german)
Similar Threads
  • kawasaki FA 06E C type controler.
    • bubloi
    • March 8, 2023 at 1:12 PM
    • Kawasaki Robot Forum
  • kawasaki manuals
    • bubloi
    • March 2, 2023 at 1:05 PM
    • Manuals, Software and Tools for Kawasaki Robots
  • Kawasaki c series controller with ux12 error -1909 servo type mismatch after battery exhaustion in controller
    • lewywri89
    • December 12, 2020 at 12:44 PM
  • Dry contacts
    • 89Seth
    • June 29, 2020 at 12:24 PM
  • Kuka ArcTechDigital Welding
    • phi
    • June 22, 2020 at 7:06 PM
    • KUKA Robot Forum
  • LOAD DETERMINATION AND KUKA.LOAD IN KUKA ROBOT
    • Counterspeller
    • May 14, 2020 at 1:52 PM
    • KUKA Robot Forum
  • Adding a second Welding Machine to a single Robot System
    • Remo
    • January 30, 2020 at 7:11 AM
    • ABB Robot Forum
  • ARC-013 No arc after 1st weld
    • BORObot2018
    • September 17, 2019 at 7:34 PM
    • Fanuc Robot Forum
  • Robot Studio functions
    • wld82ngnr_hu
    • June 17, 2019 at 2:00 PM
    • ABB Robot Forum
  • ALARM 8001 TASK#0
    • brianb
    • June 14, 2019 at 1:26 PM
    • Yaskawa Motoman Robot Forum
  • MERKLE
