Conveyor light curtain
  • Hello,
    I am working in a Box labeling application using faunc rcx10iA/L robot. In that boxes are coming in a conveyor. In that conveyor is covered with the light curtains. So my query is the light curtain should reset it automatically after the box moves and robot should start. how to do that? Is there any setting need to be done from robot side or PLC side. Kindly give your comments.
    Thanks for understanding.
  • kwakisaki
    Approved the thread.
  • Is the box breaking the light curtain?
    Is the light curtain stopping the robot?
    If so I would suggest adding another sensor to detect the box and mute the light curtain. Then the robot would not be faulted and you could also use that sensor to trigger your robot to start.
  • Hi,
    Thank you so much for your comments.
    I think this will work because, I was thinking that after the box cuts the light curtain the robot will get safety stop and it will not get automatic start. However After the reset only Robot start will happen. That was my concern. Now I found a solution.
  • HawkME
    Changed the title of the thread from “Fanuc Robot Forum” to “Conveyor light curtain”.
