Loop through Z heigths
  • KevinS94
  • March 23, 2023 at 11:02 PM
  • KevinS94
    To reduce the program size, I want to use a While loop to Loop through my program and change the Z value every time.
    The following code (only relevant lines) is wrong, I cant use the variable Zax in my positions, how to fix this?
    ____________________________
    DEF JIHAAA3()
    DECL INT Zax
    Zax=2
    LIN {X 400.000,Y 850.000,Z 207.000,A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
    LIN {X 500.000,Y 850.000,Z 8.000,A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
    $VEL.CP=0.0099
    WHILE Zax < 200
       LIN {X 500.000,Y 850.000,Z Zax, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
       LIN {X 499.881,Y 845.131,Z Zax ,A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
       LIN {X 499.526,Y 840.274,Z Zax ,A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
       LIN {X 498.934,Y 835.440,Z Zax ,A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
       LIN {X 498.108,Y 830.640,Z Zax, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
       LIN {X 497.049,Y 825.887,Z Zax, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
       LIN {X 495.760,Y 821.190,Z Zax, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
       LIN {X 494.244,Y 816.562,Z Zax, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000} C_DIS
    ENDWHILE
    END
    Thanks!
  • kwakisaki March 23, 2023 at 11:37 PM
    Approved the thread.
  • Shellmer
    52
    5
    161
    • March 24, 2023 at 3:51 AM
    I'm a bit rusty on Kuka... but maybe if you declare that 8 points globally, you can then edit the Z coordinate of all points before performing the movement.
    Not inside the point itself, but overwritting the Z value of every position before executing the movement.
    Putting a variable inside the declaration of the local point will likelly result on a syntax error, also you are not incrementing zAx so that loop will run forever.
    You should be able to access data on the point by putting $xPointName1.x or something similar, like when you access the variables through the smartpad.
    panic mode
    1,293
    13,122
    • March 24, 2023 at 1:51 PM
    you need to lookup differences between variable, constant and literal.
    inside aggregate only literals are acceptable.
    also you have other issues there:
    there is no motion parameter initialization.
    there is no initial PTP motion for BCO
    your Z value in the loop is not changed at all - even if the variable was accepted, point value would not change etc.
    this is one way to cure some of those problems. this is tailored to match your attempt.
    the other way is to leave points as they are and manipulate base.
    DEF JIHAAA3()
    DECL POS P1,P2,P3,P4,P5,P6,P7,P8
    DECL INT Zax
    DECL REAL ZaxStep
    P1= {X 500.000,Y 850.000,Z 1000, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000}
    P2= {X 499.881,Y 845.131,Z 1000 ,A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000}
    P3= {X 499.526,Y 840.274,Z 1000 ,A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000}
    P4= {X 498.934,Y 835.440,Z 1000 ,A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000}
    P5= {X 498.108,Y 830.640,Z 1000, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000}
    P6= {X 497.049,Y 825.887,Z 1000, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000}
    P7= {X 495.760,Y 821.190,Z 1000, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000}
    P8= {X 494.244,Y 816.562,Z 1000, A -90.001,B 0.000,C 0.000,S 6,T 27,E1 0.000,E2 0.000,E3 0.000,E4 0.000,E5 0.000,E6 0.000}
    IF $MOVE_BCO THEN
      BAS(#INITMOV,0)
    ENDIF
    $VEL.CP=0.0099
    Zax=0
    ZaxStep=2.0
    WHILE Zax < 200
       Zax=Zax+ZaxStep ; Z value is incremented
       P1.Z=P1.Z+ZaxStep   ; then it is applied to points
       P2.Z=P2.Z+ZaxStep
       P3.Z=P3.Z+ZaxStep
       P4.Z=P4.Z+ZaxStep
       P5.Z=P5.Z+ZaxStep
       P6.Z=P6.Z+ZaxStep
       P7.Z=P7.Z+ZaxStep
       P8.Z=P8.Z+ZaxStep
       LIN P1 C_DIS ; then program is using those points
       LIN P2 C_DIS
       LIN P3 C_DIS
       LIN P4 C_DIS
       LIN P5 C_DIS
       LIN P6 C_DIS
       LIN P7 C_DIS
       LIN P8 C_DIS
    ENDWHILE
    END
    SkyeFire
    1,059
    9,450
    • March 24, 2023 at 4:28 PM
    I would recommend creating a Base that has its Z axis aligned the way you wish to offset your paths, and use that:
    DECL FRAME _fOffset
    DECL INT nIndex
    $BASE=BASE_DATA[1] ; original Base with no offsets
    FOR nIndex = 0 TO 10
        _fOffset = $NULLFRAME ; reset to all 0s
        _fOffset.Z = nIndex * 10 ; 10mm z-shift per pass
        $BASE = BASE_DATA[1] : _fOffset ; offset the Base frame
        PTP P1
    ENDFOR
  • Print 3D
