KUKA ROBOT - THE MEANING OF :IN , :OUT IN DEFINE
  • Hi experts !
    Hi experts!
    i see many "DEF" is created with variables :IN or :OUT
    i really tried to find out about them. but still not understand
    plz explain it to me, many thanks
  • kwakisaki
    Approved the thread.
  • Also that program is not called "DEF", its WRITE_CM_SETTING.
    GLOBAL allows the program to be called from outside that file
    DEF/END is the start and end of the program
    WRITE_CM_SETTING is the name of the program which u can call with WRITE_CM_SETTING(*,*) Replace * with actual variables
    SETTINGS_IDX:IN is the integer you want to send into the program.
    VALUES[]:OUT is the integer array you return with that program
    All of this can easily be found in Kuka Operating and Programming Manual
