pauses between LIN/CIRC moves
  • mikaelcecchin
  • March 21, 2023 at 8:35 PM
  • mikaelcecchin
    7
    Hi everyone!
    I'm new here
    I would like to fix a problem with linear and circular movements.
    This movements are generated by a software CAM (Sprutcam) and upload in Kuka robot (KR C2).
    The movements are something like this...
    LIN {X 460.459, Y -90.397, Z 208.034, A -37.354, B 50.352, C -134.015} C_DIS
    CIRC {X 461.292, Y -88.808, Z 201.706, A -37.354, B 50.352, C -134.015},{X 461.958, Y -85.961, Z 195.815, A -37.354, B 50.352, C -134.015} C_DIS
    CIRC {X 460.714, Y -82.636, Z 194.563, A -37.354, B 50.352, C -134.015},{X 458.72, Y -81.113, Z 197.37, A -37.354, B 50.352, C -134.015} C_DIS
    LIN {X 458.657, Y -81.243, Z 197.598, A -37.354, B 50.352, C -134.015} C_DIS
    But between movements we can see little pouses and decelerations.
    In link below you can see what happens
    https://drive.google.com/file/d/1TD6-vg_SWIYfV65N3cdkqu4vXQTxwIRv/view?usp=share_link
    Someone can help me please?
    Thank you
  • kwakisaki March 21, 2023 at 9:06 PM
    Approved the thread.
  • MOM
    176
    7
    1,424
    • March 21, 2023 at 9:13 PM
    To me it looks like working properly
    More informations are welcome
    BTW:
    a vacuum cleaner would also be helpful. To me it looks like a big mess
  • Mentat
    61
    5
    243
    • March 22, 2023 at 8:36 AM
    Could be that $apo.Cdis is too small?
  • mikaelcecchin
    7
    • March 22, 2023 at 1:14 PM
    Thank you for answer Mentat
    But if I use a large APO.CDIS I start to have imprecision in the cornes of my geometries.
  • Mentat
    61
    5
    243
    • March 22, 2023 at 1:49 PM
    Quote from mikaelcecchin
    That's true.
    The only way I can think of to have smooth and precise motion is to convert those motions into splines, that is, if that Kr C2 controller supports them.
  • panic mode
    1,296
    13,136
    • March 22, 2023 at 2:20 PM
    code snippet in original post only shows few motion points but skips the most important part - how and what motion parameters are initialized. what is value of $ADVANCE?
  • mikaelcecchin
    7
    • March 22, 2023 at 3:55 PM
    Quote from panic mode
    thank you
    $ADVANCE is set to 5
    this is my initial parameters ...
    $VEL.CP = 1
    $VEL.ORI1 = 100
    $VEL.ORI2 = 100
    $ACC.CP = 1
    $ACC.ORI1 = 100
    $ACC.ORI2 = 100
    $ADVANCE = 5
    $APO.CDIS = 1
    $ORI_TYPE = #VAR
    $TOOL = {X 432.967, Y 0.558, Z 207.046, A -89.24, B 66.306, C -89.305}
    $BASE = {X 2516.382, Y 17.498, Z 1205.042, A 45.325, B -0.585, C -0.518}
    PTP {A1 0.000, A2 -140.000, A3 90.000, A4 0.000, A5 50.000, A6 0.000}
    PTP {A1 -0.343, A2 -106.973, A3 105.049, A4 -15.628, A5 75.600, A6 136.874}
    $VEL.CP = 0.5
    LIN {X -560.396, Y 284.76, Z 346.441, A 0, B -88.205, C 90} C_DIS
    LIN {X -560.396, Y 250, Z 346.441, A 0, B -88.205, C 90} C_DIS
    LIN {X -560.396, Y 150, Z 346.441, A 0, B -88.205, C 90} C_DIS
    LIN {X -560.062, Y 150, Z 346.161, A 0, B -88.199, C 90} C_DIS
    CIRC {X -559.52, Y 150, Z 340.535, A 0, B -87.979, C 90},{X -553.894, Y 150, Z 341.077, A 0, B -88.093, C 90} C_DIS
    CIRC {X -554.436, Y 150, Z 346.703, A 0, B -88.312, C 90},{X -560.062, Y 150, Z 346.161, A 0, B -88.199, C 90} C_DIS
    LIN {X -558.133, Y 150.1, Z 348.655, A 0, B -88.332, C 90} C_DIS
  • panic mode
    1,296
    13,136
    • March 22, 2023 at 4:35 PM
    increase this value
    $APO.CDIS = 1
    don't be afraid to make it generous - motion planner will automatically reduce actually used approximation distance when points are close.
  • mikaelcecchin
    7
    • March 22, 2023 at 6:03 PM
    increase this value
    $APO.CDIS = 1
    Thanks for help but if i increase this value i have problems with some geometries like a simple square when i have to keep the sharp corners for example.
    There is some parameter that I can control the deceleration between LIN/CIRC movements?
    In advantage, I have doubts about the ACC.CP parameter.
    I noticed that we can adjust between 1 and 10, but I don't understand how it actually works :frowning_face:
    Maybe this parameter is related to my problem.
  • panic mode
    1,296
    13,136
    • March 22, 2023 at 6:56 PM
    you cannot bend the laws of nature. robot cannot change direction instantly without decelerating or stopping. so when well defined corners are needed, approximation is not going to work there.
    $ACC.CP is a system variable. it is documented - read the system variable manual.
    its value is not limited to integers in range 1-10. this is a REAL and values 0-10 are possible, such as 0.0125 m/s2 or 9.75 m/s2
    Leon
    35
    5
    473
    • March 23, 2023 at 12:27 PM
    • #11
    If it helps, you can also use C_VEL instead of C_DIS. C_DIS sets smoothing at a certain distance of the point. C_VEL try's to keep a certain speed through a point.
    This is not a miracle worker, like Panic mode said you can not bend the laws of nature. but during some milling operations i find it easier to use. C_DIS I only use when i need a specific radius.
  • mikaelcecchin
    7
    • March 23, 2023 at 3:34 PM
    • #12
    Quote from Leon
    Hmmmm, it sound good Leon.
    I'll try this and if it works well I'll let you know.
    Thank you very much!!!
  • mikaelcecchin
    7
    • April 27, 2023 at 7:52 PM
    • #13
    Hi everyone
    I would like to report the results of my tests change parameter APO.CDIS and C_DIS per APO.CVEL and C_VEL.
    The moves are much more smooth and the pouses between movements almost disappeared.
    Thank you so much Leon, it really helped me
