  3. Cobot Help and Discussion Center
  4. General Discussion for Cobots
Safe Distance Calculations ?
  • Robotman_Doom
  • March 20, 2023 at 8:52 PM
  • Robotman_Doom
    Normally, we write a "Pre Start Health and Safety Report" for each machine. The most important part of which is the well known "safe distance calculations".
    I don't understand how to write one for a Cobot, since it does not stop when someone is near.
    Does anyone have any experience with Safety documentation for Cobots (running in Cobot mode only) ? If not Safe distance then, is there any other kind of documentation I could present ?
    Just wanted to have a quick discussion and get some direction here.
    Thank you.
  • Lemster68 March 20, 2023 at 8:54 PM
    Approved the thread.
    SkyeFire
    1,042
    9,388
    • March 21, 2023 at 12:30 AM
    • Best Answer
    As far as I know, a Cobot does not need a stopping distance, as long as it is properly configured.
    "Properly Configured" mostly applies to the "Power and Force Limitation" -- as long as the Cobot is sufficiently limited in this regard, it can be counted on to stop on contact before doing harm. Note: Some Cobots can have their "Collaborative" Mode turned on/off from inside their program, and when Collab Mode is inactive, the robot needs to be treated like a "big iron" robot.
    Also, whatever the robot is carrying must be part of the risk assessment, using the guidelines in RIA 15.06. In previous experience, putting a screwdriver on a Cobot made the robot no longer "Collaborative", b/c the P&F Limit could not be set low enough to get below the force/area ratio allowed under the RIA spec.
    So, if any human contact is covered by PFL, after performing the risk assessment, then stopping distance should be irrelevant.
Similar Threads
  • Measure Stop Time
    • edda
    • July 2, 2020 at 12:01 PM
    • KUKA Robot Forum
  • Motors for robot arm
    • principemestizo
    • September 13, 2020 at 9:01 AM
    • General Robotics Discussions - everything but NO Industrial Robots
  • Cobot
