Motor Cable A5 error,kuka KRC2
  • AD3MIN
  • March 13, 2023 at 1:40 PM
  • AD3MIN
    57
    Hello everyone,
    I am using kuka KRC2 ed05, KR-150 with version of V5.4.14,
    This morning, when I have powered on the robot, It started to showing error as Motor cable A5. I have checked, disconnected and connected back all power and encoder connections. After that it was ok for sometime and it went into same error automatically without doing anything.
    It was running ok till last week, the only change we had, fitted a new gripper to the end of arm and I did not updated that dimensions and weight to the tool.
    Can anyone kindly suggest what can be done further.
    Thanks in Advance
    Advmin.
  • Go to Best Answer
  • SkyeFire March 13, 2023 at 3:03 PM
    Approved the thread.
    panic mode
    1,280
    13,085
    • March 13, 2023 at 3:10 PM
    what is the message exactly? please post screenshot of the message.
    is it always complaining about the same axis?
  • AD3MIN
    57
    • March 13, 2023 at 3:23 PM
    Hai Panic mode,
    Message is just ' Motor cable A5'.
    yes, it is always complaining about the same axis.
    I have tried to attach the images, unfortunately I couldn't find the option for attachment.
    Regards
    Advmin
  • aknezevi.proton
    5
    73
    • March 13, 2023 at 3:38 PM
    To insert an image click this icon:
    panic mode
    1,280
    13,085
    • March 13, 2023 at 4:16 PM
    yup, what you shared is not enough. please post actual picture(s) of all the messages.
    check pinned topic READ FIRST
  • AD3MIN
    57
    • March 14, 2023 at 10:54 AM
    Quote from aknezevi.proton
    Hai aknezevi.proton,
    many thanks for your reply, unfortunately I really struggle to insert an image. I saw this icon before, but when I click there it is showing to add source and link. How to do that? do we need to add a browser link?
    Many Thanks
    advmin
  • AD3MIN
    57
    • March 14, 2023 at 5:01 PM
    Quote from panic mode
    Hai Panic Mode,
    Yesterday I had error as 'motor cable A5',that disappeared today and some other errors pop out
    no 2962 Ackn.common KSD-Error A5
    no 1136 Ackn.heat sink temperature A5
    no 118 Heat sink temperature A5
    Kindly check the attached link for images
    zLsVKFj
    Regards
    advmin
    panic mode
    1,280
    13,085
    • March 14, 2023 at 7:25 PM
    what happens if you have motor cable disconnected from drive? it is the big black connector on the bottom side of the drive. that would ensure that NO current goes from A5 drive to cable or A5 motor while drive is still part of the bus.
    do you still get overtemperature or cable alarm for A5? does the drive temperature stay low (room temperature)? because if not drive is likely bad. even so, that may not be a root problem, maybe is result of damaged cable or motor, so those would still need to be checked as well.
    as for inserting images into the post, not sure how that works for you but i open image in some image viewer or editor, crop part i am interested in (optional), use copy (Ctrl+C) ,then click into open robot forum post and use Paste (Ctrl+V). voila. for new members there is a limit of one picture per post. not sure why is that but regardless one can use some workaround. simply reply to your own thread and past another image, or compose several images into one, then post it, or paste several images into word or excel file then print it as PDF or... ... ...
  • AD3MIN
    57
    • March 15, 2023 at 3:36 PM
    Many Thanks for your Reply Panic Mode,
    1. I have disconnected the the black connector on the bottom side of A5 drive, still I get the Heat sink temperature A5 error.
    2.Yes, the drive temperature stayed low for last few days.
    3.I have swapped the encoder and power cables from A4 to A5 and A5 to A4 on the motor side, still A5 driver is in error and A4 is ok. Which ensured A5 motor is working fine.
    8H0ECvG
    I have an another robot with same drive which is in good condition, I would like to replace the drive from other robot. What are the procedure for that? I know how to do the hardware replacement but after that what should be done,do we need to configure the new drive ? what are the steps for that?
    Thanks in Advance
    advmin
    Edited once, last by AD3MIN (March 15, 2023 at 3:42 PM).
    panic mode
    1,280
    13,085
    • March 15, 2023 at 3:53 PM
    • Best Answer
    power off
    unplug cables from KSD
    use screwdriver to unlock KSD and extract it.
    then install same model (just reverse process) and then powerup. no configuration is needed.
  • AD3MIN
    57
    • March 16, 2023 at 12:38 PM
    • #11
    Hai Panic mode,
    Thanks for your valuable help, I have replaced the drive from other robot and all problems are fixed. :applaus:
    When I checked in the DSE screen, The Hardware version of new A5 drive is showing as 'Control card 'E' power card '3' . Where the Hardware version of old A5 drive was
    'Control card 'C' Power card '3', Is that going to be a problem in the future?
    Imgur
    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining…
    imgur.com
    Many Thanks
    advmin
    panic mode
    1,280
    13,085
    • March 16, 2023 at 12:47 PM
    • #12
    That is ok
Similar Threads
  • 1161 error Ackn monitoring the actual velocity E1
    • robot-cnc
    • October 6, 2021 at 8:06 PM
    • KUKA Robot Forum
  • Continuous error increasing speed on KRC2 KR210
    • Raltru
    • July 18, 2019 at 5:01 PM
    • KUKA Robot Forum
  • Kuka robot project and difficulties
    • Oatesy
    • December 17, 2020 at 5:59 AM
    • KUKA Robot Forum
  • ACKN brake error A1-A6 (After External Axis Removed)
    • Levi_SCI
    • October 26, 2020 at 8:26 PM
    • KUKA Robot Forum
  • New to Kuka, bit lost
    • Affaltar
    • October 11, 2019 at 7:38 AM
    • KUKA Robot Forum
Users Viewing This Thread
  • 2 Guests
