YRC1000 display custom message on pendant?
  • rpearls
  • March 10, 2023 at 9:05 PM
  • rpearls
    Hello all,
    I'm a new Yaskawa user and am learning my way around programming. In our system we have an air-powered manipulator with an air pressure sensor on the supply line, that is wired to the controller so it will stop operation if the pressure is low. Is there a way to send a warning message to the screen if this happens?
  • SkyeFire March 10, 2023 at 9:06 PM
    Approved the thread.
  • ljuba
    33
    5
    281
    • March 10, 2023 at 10:30 PM
    there is a way to just write a message or you can set the user alarm that would stop the execution. Specify better what exactly you want to do.
  • rpearls
    • March 13, 2023 at 1:31 PM
    I would say both. I want the program execution to stop (or pause) and a message that might say "check air supply"
  • 95devils
    235
    8
    1,949
    • March 13, 2023 at 6:04 PM
    You could program a user alarm. The text for the alarm could say “check air pressure.” You would need then to program the conditions to trigger the alarm in the concurrent I/O ladder program.
  • rpearls
    • March 13, 2023 at 7:32 PM
    Thanks for the hints, this did what I needed:
    IF ( IN#(1)=OFF ) THEN
    SETUALM 8000 "PRESSURE LOW" 0 SMODE=0
    ENDIF
  • 95devils
    235
    8
    1,949
    • March 13, 2023 at 8:07 PM
    This will only work if the instructions are in the job and the job is executing.
    Like programming, many ways to do the same thing.
    Going through the ladder is harder, if you don’t know the ladder, but works anytime the ladder is running. It is also not job dependent.
  • TSGIR
    81
    715
    • March 14, 2023 at 2:54 PM
    Quote from rpearls
    ENDIF
    If the system job function is actives on your robot, you can use your program.
    ENDIF
    The system job is always running in back of robot, if the IN#(1) = OFF the system give alarm.
    For use system job, go to JOB Menu and select CREATE NEW JOB and see in JOB TYPE are there SYSTEM JOB or not. if there are you can create a new job with SYSTEM JOB type and write your codes on it.
  • rpearls
    • March 14, 2023 at 6:24 PM
    Quote from TSGIR
    My choices are "ROBOT JOB" or "CONCURRENT JOB". Might that be the same thing? I'm looking thru my manuals but have not found an explanation yet.
  • TSGIR
    81
    715
    • March 14, 2023 at 6:54 PM
    If you couldn't find SYSTEM JOB under JOB TYPE, this function isn't active on your robot and need contact Yaskawa for active it.
  • potis
    245
    • March 15, 2023 at 9:02 AM
    you need to be in management mode (3 keys) in order to build or see any system job assuming that the function is enabled
