Pose file and accuracy problem
  • Hi everyone.
    I have a problem when reading value from pose file. I use POS2POS and OPEPOS to read coordinate value from Pose file and write to V! register.
    For example, z value of P111 is 54.232:
    1. When I modify z: 54.232 --> 54. 236 or 54.241 or any value between 54.23 and 54.25, the displayed value will always be rounded to 54.23 or 54.25, never 54.24. Even when I enter exactly 54.24, the displayed value will also be 54.23 or 54.25
    2. When I modify z: 54.232 ->54.216, the displayed value is rounded to 54.22. But when I use OPEPOS to write to V1! register, the V1! value will never be 54.216, it will be some values like 54.214xxx 54.217xx,...
    Please help me figure this out. Thank you very much.
  • Are you able to share the code you have written for this
    Of course, here is my code:
    4 POSE2POS 0,P111,End_Pos[1],1,1
    5 POSE2POS 0,P121,End_Pos[2],1,2
    6 POSE2POS 0,P211,End_Pos[3],1,1
    7 POSE2POS 0,P221,End_Pos[4],1,2
    8 POSE2POS 0,P311,End_Pos[5],1,3
    9 REM "**********************************************"
    10 REM "Variable Change(Pos -> Real)"
    11 V1% = 1
    12 WHILE V1%<=5
    13 OPEPOS 0,End_Pos[V1%],End_Pos_Real_TEMP[V1%,1],0,0
    14 REM "----------------------------------------------"
    15 REM "X,Y,Z,r,p,y,c -> X,Y,Z,Rx,Ry,Rz"
    16 End_Pos_Real[V1%,1] = End_Pos_Real_TEMP[V1%,1]
    17 End_Pos_Real[V1%,2] = End_Pos_Real_TEMP[V1%,2]
    18 End_Pos_Real[V1%,3] = End_Pos_Real_TEMP[V1%,3]
    19 End_Pos_Real[V1%,4] = End_Pos_Real_TEMP[V1%,6]
    20 End_Pos_Real[V1%,5] = End_Pos_Real_TEMP[V1%,5]
    21 End_Pos_Real[V1%,6] = End_Pos_Real_TEMP[V1%,4]
    22 REM "----------------------------------------------"
    23 V1% = V1%+1
    24 ENDW
  • Quote
    Where in the above code you have given are you modifying the Z
