I need help to design and build a solar tracker mechanism so that my solar panels can track the sun. The panels are coupled to a rack that is lying flat on my car port. There are 6 panels and they are arranged in 3 groups rack of two panels each. The 3 groups should be connected so that they can move at the same angle. I want the tracker to work with two linear actuators on opposite ends of the car port. At sunrise, the linear actuator farther from the sun’s direction tilts up the panels from its end so they can face the sun while the second actuator doesn’t work but acts as a stationary pivot. The tracker electronics actuates the actuator every 15 minutes (time duration should be configurable) to move the panels towards the sun based on input from the light sensors. By midday, when the sun is exactly overhead, the first actuator allows the panels to rest flat on the roof of the car port, then stops working. As the sun moves overhead towards the west, the second actuator takes over the work of tilting the panels while the first actuator only works as a stationary pivot. The tracker electronic control continues to work with the photo sensors at preset time interval to make the panels face the sun using the actuator to tilt it. At sunset, the second actuator rolls itself back to the original position where the panels lie flat on the car port. The whole process is repeated the following day. I need help on the right mechanical mechanism to connect all the components togethers as well as the electronic circuitry that controls everything.
Robotic solar tracker for panels sitting flat on a carport
Ogidi Olu -
March 7, 2023 at 4:18 PM -
Lemster68
March 7, 2023 at 4:47 PM Approved the thread. -
Are you living at the Äquator?
I don't understand why this needs two linear actuators. It seems like a single linear actuator, driving a cam linkage under each panel, would be sufficient. Although it seems as if if the panels are merely pivoting, they will shadow each other badly whenever the sun is very far from zenith.
Yes. i live very close to the equator
Can you please do a pencil sketch on how this your suggestion can work? Thanks in advance
