  4. Kawasaki Robot Forum
  5. Manuals, Software and Tools for Kawasaki Robots
kawasaki manuals
  • bubloi
  • March 2, 2023 at 1:05 PM
  • Closed
  • bubloi
    8
    Hello everyone, can anyone help me out with a programing manual for kawasaki FA 06E? Any help would be apreciated.
  • SkyeFire March 2, 2023 at 2:56 PM
    Approved the thread.
    SkyeFire
    1,051
    9,423
    • March 2, 2023 at 4:21 PM
    Thread
    Kawasaki Robotics Download Centre
    Kawasaki have created a download centre for Kawasaki clients to have access to the latest revision manuals when they are released.
    (Registration and approval is required to sign up to).
    Therefore, instead of requesting specific manuals at the forum, I recommend to register at the download centre where manuals and further product information is being made available including downloading of KROSET.
    Link is:
    Login:Kawasaki Robotics Download Center (khi.co.jp)
    kwakisaki
    July 23, 2021 at 5:51 PM
  • kwakisaki
    694
    4,770
    • March 2, 2023 at 6:39 PM
    FYI:
    This is an obsolete model arm now, so no support or parts are likely to be available from Kawasaki in case of replacement parts.
    What programming manual are you after?
  • kwakisaki March 2, 2023 at 6:52 PM
    Moved the thread from forum Kawasaki Robot Forum to forum Manuals, Software and Tools for Kawasaki Robots.
  • bubloi
    8
    • March 2, 2023 at 10:31 PM
    I know this model is at least 20 years old. I just need some info on programming it for 10 simple welds. I have never worked with kawasaki before and was looking for some info on the basics of this robot.
    As for the download center it requiers a Kawasaki sales person email in order to register, but since this robot is so old I think its at least at the third owner.
  • kwakisaki
    694
    4,770
    • March 2, 2023 at 11:17 PM
    What controller is it, C or D Controller?
    Are you based in the UK by any chance?
  • bubloi
    8
    • March 3, 2023 at 8:48 AM
    The controler type is C40F-A021. No I'm not from the UK. Thank you in advance!
  • kwakisaki
    694
    4,770
    • March 3, 2023 at 9:27 AM
    Quote from bubloi
    That's a shame............ :bawling:
    Kawasaki has 2 types of programming available:
    1. BLOCK Teaching which is all programming using the teach pendant.
    - Move the robot to the position, set the motion, accuracy and io parameters and record the step.
    - Do this sequentially to build your program.
    2. AS language which is all code based.
    - Requires advanced programming knowledge and programmed using a laptop online/via OLP KRoset.
    If the Kawasaki has not been butchered and has the dedicated arc welding hardware and has been wired up as per Kawasaki dedicated arc weld systems, then the dedicated programming format in BLOCK or AS language will also be arc weld specific, which will allow automatic control of the weld power source for voltage/current/wire feed controls of the power source and wire feed unit.
    The simplest method is BLOCK as standard the Kawasaki is usually setup for this and this method is literal move the robot to the required position and set the parameters and record it for the step.
    eg. just like taking a series of photographs of each individual robot position.
    Files
    C_ArcOps.pdf 4.69 MB – 235 Downloads C_ArcLang.pdf 4.53 MB – 122 Downloads
  • bubloi
    8
    • March 3, 2023 at 9:47 AM
    Thank you so much I'll have a look, tomorow is first contact with the robot.
  • kwakisaki
    694
    4,770
    • March 3, 2023 at 10:04 AM
    Pity you were not in the UK as I could offer a visit and some tuition/assistance as I do this for a living.
    I do offer remote support on a 'purchased bulk hours' which you buy x amount of hours of support from me and you use those hours for training, tech support and assistance.
    Use my contact form of my website in my signature if you would like to discuss further.
  • bubloi
    8
    • March 8, 2023 at 11:37 AM
    Hey kwakisaki, any ideea if it is possible for this type of robot and TP to turn off, the arc failure error?
    The welding source connected to the robot is just connected with 2 wires, I can use WS but it will give a arc failure error restart the arc, but because there is no input from the welding source it just fails.
    I also tried using a DO but the arc or the execution of the DO is done before the robot arives at the end of the motion. Thus it tries to start the arc in mid air. Any advice is welcome :grinning_squinting_face:
  • kwakisaki
    694
    4,770
    • March 8, 2023 at 12:07 PM
    • #11
    Quote from bubloi
    Why would you want to mask this out, that makes no sense at all.......... :hmmm:
    Why are people constantly trying to circumvent errors instead of setting the system up correctly in the first place............... :hmmm:
    Set the system up correctly, so that if the power source goes into error, then welding is stopped by the arc failure error, that is what it is there for.............. :hmmm:
    The robot is not receiving the output from weld power source to say current is flowing.
    So the output from the power source needs to be wired into the dedicated 1GN board input to resolve.
    Quote from bubloi
    This will be because of the retry settings set in the weld condition parameters.
    You have a dedicated arc weld specification system, so if it's installed correctly, has the correct hardware installed and wired correctly you want have ANY issues.
    A standard basic old school system would have:
    - Voltage and Current analog outputs wired to the power source.
    - A weld start output wired to the power source.
    - A current flow input wired from the power source.
    - A torch interference (torch collision) already configured to the controller.
    These are all available on the 1GN board and digital IO board.
  • kwakisaki
    694
    4,770
    • March 8, 2023 at 12:17 PM
    • #12
    bubloi
    Could you please start a new thread in the main Kawasaki board if you have issues or questions about the usage of your system in future please?
  • kwakisaki March 8, 2023 at 12:17 PM
    Closed the thread.
Similar Threads
  • Question about Kawasaki TCP/IP Communication on C#
    • Kasim
    • July 18, 2020 at 2:39 PM
    • Kawasaki Robot Forum
  • SeparateControl
    • A_ghost
    • February 3, 2023 at 12:59 PM
    • Manuals, Software and Tools for Kawasaki Robots
  • Kawasaki
    • Kleis
    • October 6, 2022 at 8:24 AM
  • Kawasaki D Serises Controller comunication with LabView
    • Kubansky
    • May 18, 2022 at 12:24 PM
  • What do I need to get a duaro moving to demonstrate functionality?
    • duaron00b
    • November 18, 2021 at 11:13 PM
  • Kawasaki E Series Controller
    • hetyd
    • January 6, 2021 at 11:25 PM
  • Kawasaki arc-js006
    • Lei_1943
    • March 5, 2020 at 11:34 AM
  • New to Kawasaki robots help with Software
    • ericwiz7923
    • November 12, 2019 at 2:12 PM
