how can I connect the DeviceNet scanner module with a laptop to establish communication with micrlgx 1500 lrp ? What all things are required for the communication ?
micrologix 1500 connecting with device net for kuka krc2
AD3MIN -
March 2, 2023 at 11:50 AM -
Thread is Resolved
- Go to Best Answer
95devils
March 2, 2023 at 12:02 PM Approved the thread. -
Hai everyone,
I am new with kuka,I have KUKA KRC2 with Version V5.5.16,other end I have Allen Bradly Micrologix 1500 which has devicenet scanner module 1769 SDN macid=63 also it has devicenet I/O module IL 2302 macid=10
I am trying to communicate these two modules from robot,
In DEVNET FILE I wrote as
In iosys.ini file I wrote as
I got error in the robot as
Configuration error I/O driver DN2DRV
Error on Writing,driver:DN2DRV
Can anyone provide your valuable suggestions.
Thanks in Advance
ADVMIN
- Best Answer
Scanner is another name for master. If your KRC is using DNET interface on MFC, direct communication is not possible because MFC is also a scanner. For this to work one of them need to be a master and other need to be a slave...workaround is to use suitable gateway. Each side of gateway would appear as slave to respective master
Another option is to not use MFC. Get LPDN card. This can act as master oe slave or both. .
Many thanks for your reply.
How can we make the MFC a 'SLAVE' ? Is that possible ?
cheers
No.
thanks for the reply.
Iam working on KUKA KRC2 with Version V5.5.16,other end I have Allen Bradly Micrologix 1500 which has devicenet scanner module 1769 SDN.
Today I counter another error message that is 'invalid$ tool : working envelope surveillance not possible'
What is this error means ?
cheers
It means that no Tool was active, and as such, workspace monitoring was not possible. Your active Tool Number was probably set to 0. This is fairly normal after a reboot or a program cancel/reset. The message should clear itself when you activate a valid tool.
Sorry for the late reply. Thankyou all for helping me out.
cheers.
