error 3210 position No. storage area not found
  • Hi all, I wrote on pc the code in user frame 5 and i tried import it on yaskawa robot but following error appears:
    3210 position No. storage area not found.
    I write a part of code:
    /JOB
    //NAME JOBLINELOGO102
    //POS
    ///NPOS 9000,0,0,0,0,0
    ///USER 5
    ///TOOL 0
    ///POSTYPE USER
    ///RECTAN
    ///RCONF 0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    C00000=270.9984170757008,42.99978590518003,111.0,180.00,0.00,-180.0,-30.0
    C00001=270.1941223144531,42.99978590518003,111.0,180.00,0.00,-180.0,-30.0
    C00002=269.38048198331893,42.99978590518003,111.0,180.00,0.00,-180.0,-30.0
    C00003=268.5762023925781,42.99978590518003,111.0,180.00,0.00,-180.0,-30.0
    C08997=95.28401184082031,81.99978590518003,111.0,180.00,0.00,-180.0,-30.0
    C08998=96.0099105834961,81.99978590518003,111.0,180.00,0.00,-180.0,-30.0
    C08999=96.30225504464627,81.99978590518003,111.0,180.00,0.00,-180.0,-30.0
    //INST
    ///DATE 2023/01/03 18:58
    ///ATTR SC,RW,RJ
    ////FRAME USER 5
    ///GROUP1 RB1
    NOP
    MOVL C00000 V=50.0
    MOVL C00001 V=50.0
    MOVL C00002 V=50.0
    MOVL C00003 V=50.0
    MOVL C08997 V=50.0
    MOVL C08998 V=50.0
    MOVL C08999 V=50.0
    END
    can someone help me?
  • Do you really have 9000 positions written in the header and the job?
    Does the controller have the relative job software turned on?
  • yes I have 9000 position from 0 to 8999.
    how can i activate relative job?
    many thanks
    At the first check the relative job is active or disable.
    Go to a job and select UTILITY menu and see there are RELATIVE JOB under it or not.
    If it isn't, you need to contact Yaskawa for active it.
