Backup from XRC controller with YasXfer
  • wojnas93
  • February 25, 2023 at 8:42 PM
  • wojnas93
    Is it possible to backup the program using this device connected to CN03/RS232C or teach pedant.
    I failed to connect via a 32mb CF card with a PCMCIA adapter.
    Can someone help me?
    Kind regards, Wojciech.
    Edited 2 times, last by wojnas93 (February 26, 2023 at 11:51 AM).
  • Go to Best Answer
  • massula February 25, 2023 at 10:04 PM
    Approved the thread.
  • massula
    205
    8
    1,440
    • February 25, 2023 at 10:11 PM
    Hi, wojnas93
    I suggest You edit Your post.
    Remove the Code tag (that probably came because the message was copied from some online translator), clean the links to the images and so on.
  • massula
    205
    8
    1,440
    • February 25, 2023 at 10:12 PM
    And about YasXTransfer, unfortunately I can't help, because I never used it.
  • 95devils
    235
    8
    1,951
    • February 25, 2023 at 11:11 PM
    • Best Answer
    I have not used this but according to the manufacturer’s manual yes. It lists the parameters that need to be changed to allow communication.
  • sunilpant4
    7
    • February 26, 2023 at 1:40 AM
    Try using Fresh Card and never format card card just cut and paste to delete data.
    May be new card will work.
  • XRC
