  4. ABB Robot Forum
Send string via Profinet to a PLC
  • SimoneCosti
  • February 22, 2023 at 5:24 PM
  • SimoneCosti
    10
    Goodmorning,
    Actually i'm working on a project with a CRB15000, i'm programming it with Robotstudio. The Robot is mounting a camera that is going to read some serial numbers.
    From the camera i receive a string similar to "SN1234|123" but it could be different.
    I need to cast this string into an array of byte, so i can send it to my PLC via Profinet with SetGO.
    For example:
    PERS string sendString;
    sendString:= "SN1234|123";
    SetGO SendByte0, StrgToByte(sendString{1});
    SetGO SendByte1, StrgToByte(sendString{2});
    Ecc...
    But it didn't work
    I also tried with SetGO SendByte0, StrToByte(StrPart(sendString, 1, 1)) but it didn't work.
    What is the correct way to do it?
    Thanks everyone.
  • panic mode February 22, 2023 at 5:39 PM
    Approved the thread.
  • Mr.Robot
    65
    • February 22, 2023 at 8:22 PM
    • Best Answer
    I think syntax for sending the string should be:
    sendString{10}:= :=["S","N","1","2","3","4","|","1","2","3"];
    Additionally, the \Char argument can be used to convert it to ASCII. To implement this,
    SetGO SendByte0,StrToByte(sendString{1}\Char);
    should be used. It should be noted that the string must be sent in ASCII and then converted back to a string from the PLC
    OR
    SetGO SendByte0, StrgToByte(StrPart(sendString,1,1)\Char);
    SetGO SendByte1, StrgToByte(StrPart(sendString,2,1)\Char);
  • SimoneCosti
    10
    • February 23, 2023 at 8:21 AM
    Unfortunatly i can't change the format of the string as you suggest in the first line of code.
    But in the second way it works very well! Thank you very much! :smiling_face:
  • SimoneCosti February 23, 2023 at 8:21 AM
    Selected a post as the best answer.
  • NullReference
    93
    • April 4, 2023 at 8:46 AM
    Maybe not relevant but if you want faster communication then use tcp socket to send to the plc. The difference can be in the hundreds of milliseconds
  • Sting
  • Byte
