External Axis Endless
  • Hello,
    We have an external axis endless. It can turn according to the value that give to MTE in MOVJ instruction. I use MRESET to reset the number of turn.
    I have a problem, I need the axis turn more than 32767, in the default the MTE can set only 32767. for use more than this, i use MRESET to reset the axis turn and use MOVJ for turn again but there are a problem after reset. Axis stop and start again, this is bad for my work. How can solve this problem?
    My Program is below:
    NOP
    MOVJ VJ=10
    MOVJ VJ=10 MTE= 32767
    MRESET
    MOVJ VJ=10 MTE=32767
    END
  • What is the purpose of turning so many degrees? Welding? Milling?
  • two options for solving your problem come to my mind.
    1 ) You can increase MTE= 32767 by 2 times. By creating a start point of rotation MTE= -32767 and end point MTE= +32767
    2) or paid function from the manufacturer by manipulating the secret parameter FD ( Infinite rotation (Ext axis, T axis) )
    Thank you for your options,
    Can you give me example for option 1 that you said?
    About option 2, are you sure there are function parameter for infinite rotation? Because i didn't listen about it.
  • Thank you for your options,
    Yes it exists, but involves some parameter that need the Yaskawa assistance.
    Basically the MRESET is done automatically.
    But if I remember remain a limit: you can go to a max value of 999999999 after that it's possible that could rise an alarm like 1656(AXIS ENDELESS INFO NOT GENERATED) or the controller will stop briefly to do a real MRESET.
