Profinet Communication | Boolean Registers
  • Hello!
    I would like to use the Boolean registers of a UR5e for the handshake with another Profinet device.
    I just don't understand the difference between the following commands:
    read_input_boolean_register and
    read_output_boolean_register
    In the PLC I see the T2O bit registers [0] - [7] of the robot. Which of them are input and which are output registers?
    What I would like to do:
    1. robot reaches position --> write_output_boolean_register(address, TRUE) --> Use Value as condition in PLC --> WORKS!
    2. Other Profinet device reaches target value --> BOOL variable in PLC is set to TRUE --> value is mapped to register (e.g. 2)
    How can I read the value in the robot program now?
    var1 = read_input_boolean_register (2) or
    var1 = read_output_boolean_register (2)?
    Thanks a lot!
  • Place your Ad here!
  • Doesn't anyone have an idea about the boolean registers?
    I am concerned with passing TRUE and FALSE values from the PLC to the robot and the robot reading this value change and being able to react to it.
  • read_input_boolean_register(address) : reads the Boolean value from one of the input registers, which can be accessed by a field bus
    read_output_boolean_register(address) : reads the Boolean value from one of the output registers, which can be accessed by a field bus
    write_output_boolean_register(address, value) : writes the Boolean value to one of the output registers, which can be accessed by a field bus
    On the PLC side, you should see T2O and O2T.
    O2T : PLC output to Robot input
    T2O : Robot output to PLC input
