  4. ABB Robot Forum
4400 and 140 cease to work, cabsta.c cabts.c servots.c
  • iano
  • February 14, 2023 at 4:30 PM
  • iano
    We have multiple ABB robots on site and one processing cell went unused for a month or two. I've come back to it and found that the 4400 and 140 in that cell aren't happy.
    The 4400 has an S4C+ controller and will boot, get past counting, but then shows errors:
    safevtts.c 620 Couldn't i
    runchn.c 1033 can't write
    runchn.c 1073 can't write
    runchn.c 1113 can't write
    cabsta.c 435 Count ini
    cabts.c 2430 Cansta init
    servots.c 1213 Not allowe
    I can go to the program window but it won't load or create a program.
    I can make backups or restore known good backups but the problem persists.
    We've removed the PC, reseated the boards, cleaned dust and reassembled but the problem persists.
    The robot has worn batteries and needs calibration (rev counter update) during any power cut, but this is commonly performed without issue.
    You can go to the rev counter update screen and say update but it doesn't seem to make any difference to the errors.
    It's strange that both the 4400 and 140 have issues simaltaneously. Makes me think a power cut or something upset them. The 140 has slightly different issues but lets focus on the 4400 for now. Has anyone got any idea how to sort it?
    We've tried restart, i start and x start. Run out of ideas really.
    I did image the 64MB flash disk to a spare in 2014, then that spare failed in 2016 and I swapped back but that was all to do with counting on startup, not the current errors which I've never seen before. I have ordered a new spare and will attempt to put the image on the new flash disk when it arrives but I don't think this will resolve the issue.
    Please help. Is there anything we should try?
    Edited once, last by iano (February 14, 2023 at 4:38 PM).
    Lemster68
    301
    2,491
    Blog Articles
    7
    • February 14, 2023 at 4:38 PM
    Are there status led's on the panel board indicating a fault? All wires and ethernet connections good?
  • Skooter
    173
    2,076
    • February 15, 2023 at 1:20 AM
    You could try another I/O computer card since it complains about the runchain.
    If that doesn't work, try reloading software and then the last known good backup.
  • iano
    • February 15, 2023 at 3:05 PM
    Thanks for the advice so far.
    Lemster68, Apologies, I don't know which LEDs specifically that you're referring to.
    The back of the computer has:
    Status green
    HDD orange when active (but settles to off after boot)
    Power green
    On the right of the cabinet we have a DSQC 504 with:
    CAN1 NS (network status) green, and MS green
    CAN 2 NS is not illuminated, MS is green
    On the back of the cabinet there is DSQC 509 with:
    EN not illuminated
    MS green
    NS green
    ES1 Orange
    ES2 Orange
    GS1 Orange
    GS2 Orange
    AS1 not illuminated
    AS2 not illuminated
    There's also two IO boards DSQC 328, both with:
    MS solid green
    NS blinking green
    Skooter, I'm not sure which is the IO computer card but I pulled cards from an old controller and found:
    The large CPU board with the many wired connections was already borrowed from the spare computer in 2016 and installed in this robot that is now having issues.
    The small board (X2 Axis Computer?) can be swapped but behaves in exactly the same way.
    The larger board with the ethernet port cannot be swapped, won't get beyond counting on the pendant/stuck in boot when the spare is installed. The spare may not be good but I'm not sure this is the board you wanted swapping anyway.
    We did try reloading the software over a network connection and restoring backups yesterday but it didn't alter the behaviour :frowning_face:
    After a successful boot, here is the list of errors:
    50242 Unsync due to CFG data
    38031 Resolver signal error
    50057 Joint not synchronised
    20031 Axis not calibrated
    10035 Axis not calibrated
    10211 Execution cancelled
    20311 Enable 1 open
    10014 System failure state
    10015 Manual mode selected
    20076 Not allowed command
    I'm not too concerned with the first errors as we probably just need to update rev counters, I think those errors correspond to that but I can't update the rev counters due to the system failure state.
    There's a couple of concerning messages in the errors, 38031 Resolver signal error shows:
    Too low resolver voltage detected on joint irb_6
    That isn't something I'm familiar with. Any ideas what to do?
    50242 Unsync due to CFG data shows:
    Mismatch between controller and cfg data for joint irb_6 (calibration offset or calibration position)
    or
    Valid flags for calibration offset or commutation offset not true in cfg.
    I'm still not sure if all this is to do with some messed up config file or whether some hardware has actually failed.
    Any help would be much appreciated.
    Lemster68
    301
    2,491
    Blog Articles
    7
    • February 15, 2023 at 3:22 PM
    Check the smb cable from the cabinet to the robot, including the connectors for bent/pushed in pins. There could be a short in the cable internal to the robot for axis 6.
  • Skooter
    173
    2,076
    • February 16, 2023 at 3:16 AM
    Looks like you just need to fix the resolver error.
    A6 resolver error could be the serial measurement unit, the resolver or the cables/connections in-between. Makes sure the 4-6 cable at the SMU is seated and the shielding secured, resolver connection is properly connected at the motor. DO NOT remove or adjust the resolver.
    Easiest is to try another SMU if you have one.
    If you have a spare motor, you can plug A6 motor resolver connector to the spare motor resolver connection then power up and see if it reads properly without error.
  • iano
    • February 16, 2023 at 1:20 PM
    I tried a suspicious spare SMB yesterday and it didn't work but then, following your advice, pulled a known good working SMB from another robot and it resolved the error on the 4400! Massive relief, thanks for all the help. I've labelled the spare SMB as suspected faulty so I don't waste time on it again, should probably chuck it.
    Moving on to the 140 robot, it was showing IO errors and replacing the large IO board in the PC didn't fix it but ultimately, seeing that the DSQC 509 in this controller didn't have EN, MS or NS illuminated, I tried a spare from another robot and it fixed the issue!
    Everything working, very happy.
  • Skooter
    173
    2,076
    • February 17, 2023 at 2:27 AM
    Good troubleshooting, I've had that happen to me too.
    DSQC509 age out after time and need their capacitors replaced, especially if the older ones were 85°C instead of 105°C.
    Show the controller more love by verifying all the fans and a fresh 2032 battery for the CPU card. Don't forget the filters.
  • iano
    • February 20, 2023 at 4:37 PM
    Good info, thanks. I'll take a look and see if fresh caps can revive it. There's certainly a few fans down around the place. I'll see if we can tidy things up.
