Hidden programming technic
fmiroslav -
February 4, 2023 at 7:04 PM -
Hi
Fmiroslav,
Maybe you don't need it.
it could be an example looks in your I/O mapping if that signal is used.
If this is correct you need to add an extra rack to be able to manipulate that signal. (In your Digital I/O screen)
sometimes some programmers add either signal to be replaced on-site.
Regards!
maybe the PMC function is or was used.
Accessing the (internal)PMC-IO's is done via the "10000++ " ID's.
from PMC pdf:
QuoteDO[10001-10136] K0-16
DO[10137-10160] K900-902
DO[11001-23000] R0-1499
GO[10001-11500] D0-2999
Memory for K, R, D of PMC is assigned to DO, GO of Robot.
This assignment is for compatibility with conventional models.
The assignment for K, R, D is available only for these assignment patterns. Any
other assignment pattern (Ex. Assign K0 to DO[1-8]) is not available.
best regards
PnsStarter
