Hello everyone, my english is not that good, sorry in advance. There are multiple continuous welds between the 2 parts. I'm writing the necessary routines for the welds, it welds the first piece normally, but while welding the next pieces, there is some slippage between the weld points, I still can't find the reason for this, although the piece continues to do this, even though it is fixedly connected. I don't know exactly where the problem is what can I do about it.
About the abb welding robot
- umut akkurt
- Thread is Unresolved
There is no image to see.
There was no picture, I uploaded it by mistake.
I don't understand what you are saying the problem is.
Did you not understand anything from my question?
No, not really.
I'm going to guess "slippage" is changes to the part fit after welding starts.
This could be due to heat expansion from the first weld.
Try tack welding the parts together first and then try welding the part.
I think we need to increase the number of spots and determine where the correct welding start will be better.
skooter thank you for your suggestion
