INTERRUPT PROGRAM
  • robot-cnc
  • January 30, 2023 at 1:37 PM
  • robot-cnc
    432
    Can you check if my INTERRUPT 10 is well declared in main program also if subroutine is ok?
    Thank you.
    DEF NONAME1()
    GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
    INTERRUPT ON 3
    INTERRUPT DECL 10 WHEN $IN[6]==TRUE DO STOP_MOVE()
    INTERRUPT ON 10
    $APO.CDIS = 0.5000
    BAS (#INITMOV,0)
    BAS (#VEL_PTP,20)
    BAS (#ACC_PTP,20)
    $BASE=BASE_DATA[1]
    ;$BASE={X 2000, Y 0, Z 1200, A 90, B 0, C 0}
    $TOOL=TOOL_DATA[1]
    ;$TOOL={X 503.173, Y 1.337, Z 101.069, A 0, B 90, C 0}
    $OUT[1]=TRUE
    $OUT[3]=TRUE
    $advance=3
    $VEL.CP=0.167
    PTP {A1 0.000, A2 -90.000, A3 90.000, A4 0.000, A5 0.000, A6 0.000, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
    PTP {A1 3.745, A2 -90.330, A3 101.473, A4 -113.300, A5 26.474, A6 115.693, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
    LIN {X 0, Y 0, Z 10, A 110.424, B 0, C 180} C_DIS
    LIN {X 0, Y 0, Z 0, A 110.424, B 0, C 180} C_DIS
    LIN {X 731, Y 0, Z 0, A 130.502, B 0, C 180} C_DIS
    LIN {X 731, Y 243, Z 0, A 133.014, B 0, C 180} C_DIS
    LIN {X 0, Y 243, Z 0, A 110.424, B 0, C 180} C_DIS
    $OUT[1]=FALSE
    $OUT[3]=FALSE
    INTERRUPT OFF 10
    END
    DEF STOP_MOVE()
    BRAKE
    WAIT FOR $IN[6]==FALSE
    WAIT SEC 0.2
    RESUME
    END
  • Go to Best Answer
    panic mode
    1,278
    13,079
    • January 30, 2023 at 2:52 PM
    individually interrupt declaration, ISR STOP_MOVE() and programmed motions are ok but they do not fit together. they need to form a functional structure and that is not the case. also it is not clear what the objective it.
    if you want to use it to pause and then continue program, remove RESUME command.
    if you want to use it to stop motion (and cancel it), you need RESUME but motions need to be moved into own subprogram with something to stop arp from leaving that subprogram early..
    SkyeFire
    1,051
    9,423
    • January 30, 2023 at 3:00 PM
    What are you trying to accomplish? The way you have set up the STOP_MOVE subroutine, it seems like you only want to pause the motion. But the RESUME command (which is very badly named) will terminate the motion that was in progress when the Interrupt fired, and try jumping to the next motion command. And with Approximated motions, this can get... interesting.
    Also, any Interrupt subroutine should start with an INTERRUPT OFF for the Interrupt that calls it. You can also add an INTERRUPT ON at the end if you want to keep monitoring the Interrupt, but you don't want the Interrupt to be re-triggered while the robot is at that WAIT SEC 0.2, for example.
  • robot-cnc
    432
    • January 30, 2023 at 4:17 PM
    the scope is untill spindle reach up working frequency, my IN[6] is true, when reach target frequency, for ex. 50 hz, IN[6] become false.
    While IN 6 is true I want robot don't move, when is false , spindle run on 50hz, robot can move.
    That means eveen when spindle stop from any error , robot will stop not keeping frequency of 50 hz cause will decrease to 0
    panic mode
    1,278
    13,079
    • January 30, 2023 at 5:25 PM
    that is not going to work...
    interrupts are edge sensitive, not level sensitive. and logic is reverse.
    you can simply get rid of the interrupt and after first PTP motion add
    WAIT FOR $IN[6]==FALSE ; spindle speed reached
  • robot-cnc
    432
    • January 30, 2023 at 6:01 PM
    it's ok, but I want when $IN[6]==TRUE robot to stop, when become false to restart from last point remained
    panic mode
    1,278
    13,079
    • January 30, 2023 at 6:21 PM
    Quote from panic mode
    input is a BOOL so changing signal has two transition edges: rising edge and falling edge.https://www.scilab.org/signal-edge-detection
    normally interrupt reacts only to one of them so if goal is to respond to both, one would need two interrupts (one for rising, one for falling edge) unless additional flag is used and signal compares the two.
    when you start, spindle is off and input6 is already TRUE... but your interrupt is looking for transition to TRUE. but there is no transition (change of state) when going from TRUE to TRUE.
  • robot-cnc
    432
    • January 30, 2023 at 7:24 PM
    You mean for pause and continue such a variant:
    DEF NONAME1()
    INTERRUPT ON 3
    INTERRUPT ON 10
    INTERRUPT OFF 10
    END
    DEF STOP_MOVE()
    BRAKE
    WAIT SEC 0.2
    END
    And this interrupt of program (pause) will occur at any moment while all program running ?
    Would make sense to think on IF conditionality to introduce instead in sps.sub?
    PLC loop section for ex.
    I am thinking that postprocessor that write my src files should be setted to automatically write in each src file, usually being many. So, is excluded to manually do all these instructions .
    panic mode
    1,278
    13,079
    • January 30, 2023 at 7:36 PM
    yes, that is what code without RESUME would look like. and that should do the trick except on start. because on start first transition is non-existent(your interrupt is looking for TRUE on input 6 and that is already TRUE). so you need to work around that initial case. for example add command
    just after interrupt on...
    that will make robot wait first time.... and after that interrupt will take care of it.
  • hermann
    406
    2,609
    • January 30, 2023 at 10:17 PM
    • Best Answer
    One more thing always should be done:
    switch off the interrupt when entering interrupt service routine, and switch on just before leaving it.
  • robot-cnc
    432
    • January 31, 2023 at 5:47 AM
    • #11
    Thank you Panic, will try that.
  • robot-cnc
    432
    • January 31, 2023 at 5:50 AM
    • #12
    Quote from hermann
    Just when using Global Interrupt with outside subroutine from main program or even when using Interrupt simple declared with subroutine in main program, as above?
  • hermann
    406
    2,609
    • January 31, 2023 at 7:19 AM
    • #13
    Always
  • robot-cnc
    432
    • January 31, 2023 at 10:45 AM
    • #14
    Like that. What about red instructions from main program , remain there .
    DEF NONAME1()
    INTERRUPT ON 3
    INTERRUPT ON 10
    INTERRUPT OFF 10
    END
    DEF STOP_MOVE()
    INTERRUPT OFF 10 ; deactivate interrupt
    BRAKE
    WAIT SEC 0.2
    INTERRUPT ON 10 ; reactivate interrupt
    END
    panic mode
    1,278
    13,079
    • January 31, 2023 at 2:45 PM
    • #15
    those are still needed.
    SkyeFire
    1,051
    9,423
    • January 31, 2023 at 3:47 PM
    • #16
    Quote from robot-cnc
    DEF NONAME1()
    INTERRUPT ON 3
    INTERRUPT ON 10
    INTERRUPT OFF 10
    END
    DEF STOP_MOVE()
    BRAKE
    WAIT SEC 0.2
    END
    All four are needed, as Panic said. Also, the INTERRUPT ON 10 in the NONAME program should be placed as late in the program as possible, so that the the Interrupt is only active during the motions that may need to be interrupted. Likewise, the INTERRUPT OFF 10 should be as early as possible in the program.
    For example: (the moves to/from Home are not interruptible, only milling moves when the spindle should be at speed)
    PTP xHOME ; start from Home position
    PTP xAboveStartPoint ; start spindle here
    $OUT[SpindleOn] = TRUE
    WAIT FOR $IN[SpindleAtSpeed]
    WAIT FOR $IN[6]==FALSE ; ensure signal is not in the Interrupt state
    INTERRUPT ON 10 ; arm interrtup
    LIN xMillPoint1 ; plunge into workpiece
    LIN xMillPoint2 ; first leg of cut
    LIN xMillPoint3 ; 2nd leg
    LIN xMillPoint4 ; 3rd leg
    LIN xMillPoint5 ; final leg
    LIN xAbovEndPoint ; pull out of workpiece
    INTERRUPT OFF 10 ; disarm interrupt
    $OUT[SpindleOn] = FALSE ; stop spindle
    PTP HOME ; return Home
  • robot-cnc
    432
    • February 1, 2023 at 8:03 PM
    • #17
    Code that works :
    DEF NONAME1()
    INTERRUPT ON 3
    $APO.CDIS = 0.5000
    BAS (#INITMOV,0)
    BAS (#VEL_PTP,20)
    BAS (#ACC_PTP,20)
    $BASE=BASE_DATA[1]
    $TOOL=TOOL_DATA[1]
    $OUT[1]=TRUE
    $OUT[3]=TRUE
    $advance=3
    $VEL.CP=0.167
    INTERRUPT ON 10
    $OUT[1]=FALSE
    $OUT[3]=FALSE
    INTERRUPT OFF 10
    END
    DEF STOP_MOVE()
    INTERRUPT OFF 10
    BRAKE
    WAIT SEC 3
    INTERRUPT ON 10
    END
    Thank you all !
Similar Threads
  • Interrupt when testing in T1
    • Stampy
    • January 26, 2021 at 6:54 PM
    • KUKA Robot Forum
  • Interrupt Example
    • SkyeFire
    • March 18, 2021 at 8:25 PM
    • Manuals, Software and Tools for KUKA Robots
  • Interrupt not working when program is stopped
    • Xerces
    • August 14, 2019 at 6:31 PM
    • KUKA Robot Forum
  • Measurment of tool with interrupt when the toolsetter/button is clicked and then unclicked
    • martenH
    • November 30, 2021 at 4:02 PM
    • KUKA Robot Forum
  • Program stuck executing motion command (LIN_REL), but robot is not moving.
    • RoboterEST
    • July 15, 2021 at 8:50 AM
    • KUKA Robot Forum
  • Wait on input during motion?
    • n0909
    • June 1, 2021 at 10:39 AM
    • KUKA Robot Forum
  • interrupt in the interrup trajectory program
    • watchcat
    • July 24, 2020 at 1:05 PM
    • KUKA Robot Forum
  • Recommendations to search a part?
    • robotecnik
    • December 27, 2019 at 10:54 AM
    • KUKA Robot Forum
